Old Sep 20, 2002, 12:22 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
homemade remote actuator
I built this just before I went on holiday and before RCmicroflight's article showing a similar idea. It is based on what has been coined the tabmag in the UK by Eric Hook, he produced the first I ever saw although it was not built like this one.
I hope the photo makes sense, the coil is a tatty old self wound 100ohm job and the structure is made from pcb material although ply would be as good and lighter. The wire is piano but it should be copper/brass. This was a case of use steel or have no actuator for this late night creation.
It is esentially the same as a bird actuator except that the hinging is not that of the control surfaces. I added a pull-pull arm to mine.
I should mention that the wire peice can be made so that it wraps around the magnet, this is probably better than having a small balsa peice holding the magnet, also easier especially with copper wire.
This will be in an article but it seemed silly not to share it here as well, I suspect that others will fine tune the design and that can be presented.
Hope this helps those with a heavy tail.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Sep 20, 2002, 01:05 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Great minds think alike - I had doodled a design like that but my plan was to use litho plate for the frame (or alu from a beer can, but then I would have to empty it first )
You could loose the output arm by just extending the arm that holds the magnet.
Michael
epilot is offline Find More Posts by epilot
Old Sep 20, 2002, 01:15 PM
Sticky Shepherd
Oxford/England
Joined May 2001
The reason for the arm is that it was easy to drilln two holes then form them from the wire.
Graham
Old Sep 20, 2002, 01:37 PM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Pretty cool
Who is gonna start manufacturing these things? It would seem like they would be more and more readily available.
Any possibility of explaining (or showing) how the wires lead into the wrapped coil?
FANMAN is offline Find More Posts by FANMAN
Old Sep 20, 2002, 01:41 PM
Sticky Shepherd
Oxford/England
Joined May 2001
The process of making one is as easy as making undercarriage. Just a bit of wire bending. I sell bare coils 100/200ohm as do DU for the RFFS100 or you can wind your own. I might make a bending jig if there is enough interest, could do one for the RFFS coils as well.
I have a small circuit board bonded to the coil, this allows the wires to be soldered on. These beasts were replaced with homemade litz wire afterwards so save a few pounds of weight
Graham
Old Sep 20, 2002, 01:52 PM
dhurd is offline
Find More Posts by dhurd
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Fanman,
IF your looking for an actuator that has a control arm, someone already is manufacturing them. Bob Selman's actuators have control arms and alow you to remotely mount the actuators. Bob sells them (obviously) as well as myself. But then you don't get the satisfaction of having done it yourself.
Dan
DWE
www.smallrc.com
dhurd is offline Find More Posts by dhurd
Old Sep 20, 2002, 09:11 PM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
How much does it weigh Graham? I might give this a shot.
Trizza is offline Find More Posts by Trizza
Old Sep 21, 2002, 04:24 AM
Sticky Shepherd
Oxford/England
Joined May 2001
Not a lot, 0.7g possibly but it is over built and should weigh less, slap my wrists.
Graham
Old Sep 21, 2002, 06:45 AM
Trizza is offline
Trizza's Avatar
Joined Feb 2001
Right I think I'll give one a shot soon.
As an aside: I successfully made my first SMD version of my DPC/ESC. It weighs 2.5g with wires, the circuit board makes up a bit over a gram of that weight! I'm thinking of trying a piggybacked version.
Old Sep 21, 2002, 09:03 AM
Sticky Shepherd
Oxford/England
Joined May 2001
By the sounds of it you used fairly thick circuit board. If you have a dremel and drumsander bit you can make it super thin and light.
Graham
Old Sep 21, 2002, 10:47 AM
Sparr is offline
Find More Posts by Sparr
Crashmaster Extraordinair
Clarksville, TN
Joined Apr 2002
Bob Selman's MagAct is very similar to what you show here except that the magnet is mounted on an axis inside the coil and the arms are directly connected to the magnet. Nick Leichty also makes one that I havent had the pleasure of using but is much smaller and probably the same design as you show, possibly with the axle going through the coil instead of around (a much lighter solution considering the music wire for the axle is one of the heavier parts).
Bob Selman's MagAct (picture is of two mounted in the mutually-centering arrangement):
Cost: $15
Weight: 2.1g
Nick Leichty's Standard Actuator:
Cost: $40 / $75 / $100
Weight: .25g / .15g / .09g
The second and third numbers are the Mini and Micro versions of his actuator.
Also, RC Microflight published an article this month on doing a conversion of a standard actuator (coil+magnet) to a pull-pull arrangement by mounting it in a flat surface and attaching a metal yoke to the magnet that pivots on an axis outside the coul and has two attachment points for the strings. Unfortunately they dont provide any really good close-up pictures of the real thing and I dont want to link to the plan images themselves (subscribe if you want them, you wont regret it!).
Cost: scrap wire
Weight: coil+magnet+.25g
Sparr is offline Find More Posts by Sparr
Old Sep 21, 2002, 10:51 AM
Sparr is offline
Clarksville, TN
Joined Apr 2002
also, something RC Microflight didnt think of and that I have been using in all of my pull-pull actuators since Bob Selman thought of it... If youre going to use two actuators, mount them so that the magnets are aligned when centered and have perpendicular axes of rotation. With MagActs the recommended spacing is approx 1" but you can adjust this to produce more or less centering force. Having them aligned makes them pull each other back to center, and having their axes of rotation perpendicular to each other (and to the alignment axis) insures that the magnets dont rotate each other off center (if you make the rotation axes parallel then when you turn one magnet the other will turn too).
Old Sep 21, 2002, 12:38 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
This is something I cobbled up based on a drawing by Graham some months ago. It uses a stock DU coil, and is made from 1/8" bass wood.
Dave W.
Dave Wulff is offline Find More Posts by Dave Wulff
Old Sep 21, 2002, 01:25 PM
Sticky Shepherd
Oxford/England
Joined May 2001
Spar, the point about this actuator is that it is easy to make yourself. The one shown in RCmicroflight is the same principle but I made mine before seeing that but it's (mine) not origional.
Nicks actuators use two coils with pivots between them I believe. Jberg has also done this as you will see in his depron guide mite thread.
The weight of the one I have made could be much less, a balsa base plate and 1/64th ply for the end plates. Then use aluminium wire for the axle etc?
Graham
Old Sep 21, 2002, 01:45 PM
Andy Birkett is offline
Find More Posts by Andy Birkett
Was that my 15 minutes?
Andy Birkett's Avatar
Leicester. UK
Joined Jan 2002
Here my (unfinished) effort, waiting coil
This is made of a 3mm strip of card soaked in cyno and wrapped round the 3mm magnet. Two .5mm pins are the drilled into it and the all thing mounted on a piece of brass shim.
Andy Birkett is offline Find More Posts by Andy Birkett
My first attemp at remote actuator building Prashanth Scratchbuilt Indoor and Micro Models 15 Nov 21, 2006 02:03 PM
remote actuator questions vinnyg Scratchbuilt Indoor and Micro Models 4 Apr 27, 2004 10:00 PM
new remote actuator bleriot 11 Scratchbuilt Indoor and Micro Models 3 Aug 15, 2003 03:53 PM
Remote Actuator Design Jgardner Scratchbuilt Indoor and Micro Models 29 Feb 28, 2003 01:48 PM
remote actuator how-to davekra Scratchbuilt Indoor and Micro Models 9 Oct 02, 2002 08:08 AM
