Old Aug 23, 2002, 10:25 PM
Chris3D is offline
Find More Posts by Chris3D
Chris3D's Avatar
Joined Apr 2001
Come and get it - MicroMoth plan!!
Here it is: http://www.chris3d.com/files/micromoth.pdf
Give it a try and let me know if you run into trouble or find any typos or anything.
-Chris
Chris3D is offline Find More Posts by Chris3D
Old Aug 23, 2002, 10:43 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Chris,
That is a very nice plane, plan, and construction notes. Hopefully a lot of people will use this to get into scale RFFS-100 based planes. Thanks for going to the effort, and making this available to everyone.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Aug 23, 2002, 11:19 PM
FLB is offline
FLB
Find More Posts by FLB
FLB
FLB's Avatar
Montreal-Toulouse
Joined Jul 2002
Hi,
Nothing special to say. Just thanks to share all that work. Gordonjohnson has already found the good words.
Regards
Frederic
FLB is offline Find More Posts by FLB
Old Aug 23, 2002, 11:40 PM
Paul Penney is offline
Find More Posts by Paul Penney
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
Fabulous peice of work! A good quality artical and plan.
With your permission I would like to host it on my site as a free plan.
Paul
www.canadianmodelsupply.com
Paul Penney is offline Find More Posts by Paul Penney
Old Aug 24, 2002, 12:01 AM
Chris3D is offline
Chris3D's Avatar
Joined Apr 2001
Thanks everyone, I'm more than happy to make it available, and I too hope it inspires more scale models for the RFFS-100.
Paul, sure thing, but there may be some updates to the plan based on any feedback I get. Hopefully a few people will build it and let me know if anything is unclear. Just keep an eye on this thread to see if it gets updated. Maybe for the time being, you could just link to the file on my site.
-Chris
Old Aug 24, 2002, 12:33 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
Lovely work Chris! Great plan. Great model.
The plan is sitting in the out tray of my printer now. I guess I'll have to go get some more 1/32 balsa
Trizza is offline Find More Posts by Trizza
Old Aug 24, 2002, 01:42 AM
DSO is offline
DSO
Find More Posts by DSO
DSO
Joined Aug 2002
Great plan man
And sure helps those that R trying to get themselves into the micro flight world
Beautifuly made, and a wonderful model.
Cheers.
DSO is offline Find More Posts by DSO
Old Aug 24, 2002, 02:47 AM
jk is offline
jk
Find More Posts by jk
jk
jk's Avatar
Huntington Beach, CA
Joined Apr 2001
that is simply beautiful!
and thanks for the well documented instructions!
johnk
jk is offline Find More Posts by jk
Old Aug 24, 2002, 08:34 AM
Fly_joy is offline
Find More Posts by Fly_joy
Fly_joy's Avatar
Rochester, NY
Joined Mar 2001
THANK YOU for a great contribution to the micro community.
Fly_joy is offline Find More Posts by Fly_joy
Old Aug 24, 2002, 08:49 AM
Chris3D is offline
Chris3D's Avatar
Joined Apr 2001
Thanks again, everyone, for the kind comments.
A quick note to anyone building one - the CG as indicated on the plan is incorrect. The first version of the plane I built had the top wing almost directly on top of the bottom wing - not set forward as in this version. I just test flew the plane this morning and it was a bit hairy... I've already re-located the battery up into the cowl beneath the motor, which will hopefully correct the problem. As soon as I can test fly it again, I'll update the plan.
This shouldn't necessitate any major changes, but I'd hold off on gluing in the firewall (F1) until I can verify that the problem is fixed. If the CG still needs to be moved forward after moving the battery into the cowl, moving F1 forward slightly should do the trick, as it will also move the motor forward with it.
Sorry for any inconvenience...
Old Aug 24, 2002, 04:57 PM
trevorjw_uk is offline
Find More Posts by trevorjw_uk
U.K.
Joined Nov 2000
Chris,thankyou for posting your plan.
I have started building, but I am in the U.K. I an not allowed to use 72Mhz, so I am using an I.R. system.
Keep up the great work,
Best regards,
Trevor.
trevorjw_uk is offline Find More Posts by trevorjw_uk
Old Aug 24, 2002, 06:05 PM
Chris3D is offline
Chris3D's Avatar
Joined Apr 2001
Thanks Trevor, make sure you have the latest version of the plan. I just updated it a few hours ago with the battery relocated into the cowl, but haven't been able to test fly it as it's been too windy.
Old Aug 25, 2002, 09:54 AM
CalmAir is offline
Find More Posts by CalmAir
Missouri
Joined Jul 2002
Hi Chris3D
Great job on the MicoMoth. I downloaded the plans. What amount of dihedral is used on the wings?
Regards,
Dale
CalmAir is offline Find More Posts by CalmAir
Old Aug 25, 2002, 10:04 AM
Chris3D is offline
Chris3D's Avatar
Joined Apr 2001
Hi everyone,
I just updated the plan (no changes to the actual plan from yesterday, just a few changes to the construction notes). Regarding the CG, it's perfect where indicated, and I needed to add 2 pennies to the nose to get it to balance there. This likely wouldn't be necessary if the plane is colored with markers or something lighter than the watercolors I used. For every gram added way back on the tail, it takes about 4 in the nose to compensate... If you're using NiCads, all this is irrelevant, as the plane can be easily balanced by moving the battery forward or back between F1 and F2.
As soon as my battery is charged, I'll fly it again and try to get some in-flight photos...
-Chris
Old Aug 25, 2002, 10:13 AM
Chris3D is offline
Chris3D's Avatar
Joined Apr 2001
Hi Dale, make sure you grab the latest version of the plan, I just updated it a few minutes ago. Regarding the dihedral, mine has about 3/4 of an inch at the wing tips, but that was a bit excessive and I corrected this in the plan before I posted it a few days ago. I'd say 1/2 inch at the tips would be plenty. For more scale appearances, the bottom wings should have a little more dihedral than the top.
New Jitterbug Videos! Come and get 'em Martin Hunter Parkflyers 56 Apr 28, 2007 10:06 AM
For Sale Come and get it sale outsidestuff Aircraft - Electric - Airplanes (FS/W) 1 May 28, 2005 09:22 AM
Hitec Spectra Synthesized Module - $55 shipped come and get it! Matthew Cotten Aircraft - General - Radio Equipment (FS/W) 8 Mar 25, 2005 10:27 AM
Come get em! Dynamic 3D plans. Thomas Manson 3D Flying 6 Mar 19, 2004 01:01 AM
Come Get Some all you Raider Fans spreslar Slope 14 Apr 28, 2003 07:20 PM
