Go Back   RC Groups > Aircraft - Electric - General > Power Systems
Old Jul 01, 2002, 07:55 PM   #1
Dick Curtis's Avatar
Dual Motor Propellor Thrust Steering??
I am involved in a scale model flying boat project . The model has a large wingspan and two Astro 90's. The plane hasn't a water rudder. Any ideas on how to set up to steer during takeoff
by varying the motor thrust.? I'm using an ESC on each motor but from a single transmitter it's not clear what set up would wor,k if any.
...Dick
Dick Curtis is offline Find More Posts by Dick Curtis   Reply With Quote
Old Jul 01, 2002, 08:12 PM   #2
That sickening crunch..
Andy W's Avatar
That would work, although I expect the turn rate would be low. It would be fairly easy to program with an appropriate transmitter. For a model of this size, however, I have to wonder why you don't add a water rudder?
..a
Andy W is offline Find More Posts by Andy W   Reply With Quote
Old Jul 01, 2002, 10:36 PM   #3
You could probably do it with an advanced computer radio using seperate channels for each esc and mixing in rudder inputs with the throttle input to one of the motors.
Wouldn't a water rudder be easier??
My experience with flying boats (4) is that a water rudder is mandatory to move crosswind.
But mine were single engined.
If appearance is the problem, make it out of transparent Polycarbonate ( Lexan)
Good luck, sounds like a monster model!!
Dave
DaveW is offline Find More Posts by DaveW   Reply With Quote
Old Jul 02, 2002, 12:05 AM   #4
Gold Member
Kevin Murray's Avatar
There is a section on exactly how to do this in the book "Getting The Most Out of Futaba's 8-Channel Radio Control Systems" by Don Edberg.
It uses 3 programable mixers and 3 sources of input from you.
Rudder stick input
Throdel stick input
Ch 8 rotory knob to syncronise the rpm on the 2 props (not nessicary on an e-plane ? )
Kevin Murray is offline Find More Posts by Kevin Murray   Reply With Quote
Old Jul 02, 2002, 12:56 AM   #5
Gold Member
Jurgen Heilig's Avatar
You can use the same Set-up I use for my Twin-Jet. Jürgen
Differential Thrust Set-up (requires three free mixers):
Set-up based on JR functions: Function 1 - Throttle (motor 1)
Function 2 - Aileron
Function 3 - Elevator
Function 4 - Rudder
Function 5 - Free (used for second motor)
Mix 1: Function 1 (Master - Throttle motor 1) to Function 5 (Slave - Throttle motor 2) + 100%
Mix 2: Function 4 (Master - Rudder) to Function 1 (Slave - Throttle motor 1) + 100%
Mix 3: Function 4 (Master - Rudder) to Function 5 (Slave - Throttle motor 2) - 100%
How does it work?
Mix 1 ensures that both motors react on throttle stick movements as if connected to a single ESC. Moving the rudder stick to the left will reduce the power of the left motor and increase the power of the right motor (provided it is not already running at full power).
Flying at full power and applying full rudder will reduce one motor to half throttle. Maximum effect is achieved at half throttle where full rudder will stop one motor and bring the other one to full power. While conventional rudder becomes more effective with increasing air speed, differential thrust is most effective at low speeds. Stall turns are most impressive and you can even spin an otherwise extremely stable model.
Jurgen Heilig is online now Find More Posts by Jurgen Heilig   Reply With Quote
Old Jul 02, 2002, 08:33 AM   #6
Larry Dudeck's Avatar
I had my first differential turning experience yesterday.
My TwinStar tossed a prop during hand launch. Immediate lack of control, just a tight right hard turn. The 5 or 6 feet of launch altitude disappeared in about 1/2 second.
Hard hit, broke the aft wing hold down.
This was the first time I ever lost a Gunther prop. Usually I remove the rubber hubber, ream the prop and use an aluminum prop adapator. These were stock.
Back to the prop adaptors.
Larry Dudeck is offline Find More Posts by Larry Dudeck   Reply With Quote
Old Jul 02, 2002, 03:44 PM   #7
Thanks all for the computer radio programming ideas. The reason for no water rudder is that this is a scale WW1 twin biplane that will be flown for a museum interactive movie to be made and then hung in the museum. The original used the engines for taxi turning and we want the model as true to full size performance as possible. It is large -span of 5.4 meters.
Question propellor thrust calculations pwinslow Fuel Plane Talk 4 Sep 20, 2007 12:00 PM
HW 750 dual motor single fan Plane Crazy Electric Ducted Fan Jet Talk 196 Dec 08, 2004 08:19 AM
Question Anthem dual motor geardrive. RobZ Electric Plane Talk 3 Mar 01, 2002 11:54 PM
Dual motor IPS Dx out yet? hardlock Parkflyers 0 Feb 12, 2002 06:02 PM
IPS factory dual motor DNA Parkflyers 6 Jan 12, 2002 10:32 AM
Bored? Want to fight?
Join the RCGroups clan!
