Old Jun 26, 2002, 11:40 AM
TheAddler is offline
Find More Posts by TheAddler
Moderated. Severely.
TheAddler's Avatar
Sonoma County, California
Joined Apr 2002
Plane for an Astro 010?
So I have this Astro 010 16turn Direct Drive. I'm wondering what plane to put it on. I'm looking for something fun. (aerobatic) I've heeard it works good with the Lil Hornet, but its not a geared motor...
I was also looking at the Split 280 at Hobby-Lobby.
Any thoughts on either of these, or on something else?
Thanks!
Darren
TheAddler is offline Find More Posts by TheAddler
Old Jun 26, 2002, 01:33 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
LOL! I'm in the same position, I have one of these with no plane to put it in!! I tried it in my Pop Fly, but it's too heavy for something like that. I was really annoyed when I discovered that the advertised weight of 1.3 ounces in just the motor, and the ESC alone weighs another 1.0 ounce. That's a lot of weight to plunk in a parkflyer, especially when the thrust isn't that great on anything less than 8 or 9 cells. I'm not sure what to put mine in either. It looks like a pylon racer type plane is the best choice, something like the Split 280 you mentioned.
Tres Wright is offline Find More Posts by Tres Wright
Old Jun 26, 2002, 01:51 PM
pullin-gs is offline
Find More Posts by pullin-gs
Arlington,VA USA
Joined Jan 2001
Do a search on 010 (in the title) and you will find many threads discussing planes that successfully use the motor. For direct drive sport flying, the "pylon" type flyers work well as has been mentioned by Tres. The first plane I used it on was a "And-Now" type parkflyer.....it s*cked. I never tried another parkflyer with this motor again.
For a more relaxed flyer, a powered HLG (1.5 meter or so) glider is an option worth considering. BTW, the below geared glider uses a 16T motor, 8x700Mah packs (the same packs my Hawk-010 powered plane uses).
Pullin'
pullin-gs is offline Find More Posts by pullin-gs
Old Jun 26, 2002, 01:56 PM
GoEFlight is offline
Find More Posts by GoEFlight
AeroMicro
GoEFlight's Avatar
Santa Clara, CA
Joined Sep 2001
You can use the GWS EPS-300C AS gearbox with a little modification to accomodate Astro 010 and Robinson Racing 64P 16T pinion as shown in the attached picture. I may offer this as a bundle pack to get people up and runing out of the box. Pinion gears are on order.
This setup works very well with Lil Hornet and Mountain Model Switch Back using APC 10x7 SF prop and 10-cell AAA 720 mAH Ni-MH packs.
GoEFlight is offline Find More Posts by GoEFlight
Old Jun 26, 2002, 02:11 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
GoEFlight beat me to it. Switchback! I'm not sure how much difference the 16 turn will make compared to the 14 turn that's usually used for geardrive.
My SB flies great with the 010. I'm using the Astro gearbox and esc. A Castle Creations Phoenix ESC could be used to save over 1/2 ounce of weight. And the GWS gearbox is a 1/2 ounce less than the Astro gearbox.
BC
Basketcase is offline Find More Posts by Basketcase
Old Jun 26, 2002, 02:14 PM
Arlington,VA USA
Joined Jan 2001
My Omega 1.5 HLG also uses a gutted GWS gear sets. I use an "A" gear set and the original GWS pinion that I drilled out (it is brass) and press-fitted on. Here is an early-version from about 14 months ago that I used on an "and-now".
I have since shedded the GWS casing in favor of a tube mounted directly to the top of the motor. I made an aluminum motor-tube the diameter of the 010 (I then slid the 010 inside it), and epoxied a 1/4" carbon tube (self-lubricating, and cheap) to the motor-tube. The carbon tube had an inside diameter that was exactly right to fit the GWS prop-shaft.
Pullin'
Old Jun 26, 2002, 02:29 PM
AeroMicro
GoEFlight's Avatar
Santa Clara, CA
Joined Sep 2001
Hello pullin-gs:
Can you provide a picture of your new setup with the Astro 010? Thanks.
Old Jun 26, 2002, 08:23 PM
W.C.mach is offline
Find More Posts by W.C.mach
Flat out
W.C.mach's Avatar
Plymouth, MA
Joined Mar 2002
The House of balsa mico cub was made for the AF010 and it's a real nice kit to build. Warren
W.C.mach is offline Find More Posts by W.C.mach
Old Jun 26, 2002, 09:56 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
I'd have to second the HOB Cub, I love it, I fly mine on 7 x 600 nimh cells, plenty of power to loop and roll (rudder only roll) from level flight. I average 15 minute flights.
Incidently I'm working on a new design right now for the 010 or DD speed 300. Still in electronic format, soon to be a real model. Its a little low winger sport plane with wheel pants. More to come......
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Jun 27, 2002, 05:01 PM
Tigger is offline
Find More Posts by Tigger
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
Astro 010 Plane
I have one in a Wattage Hawk (aileron version) that really is a lot of fun. I run it on AAA Maxell 700's with great results. 6 cells mellow, 7 cells mild, and 8 cells wild!
tIgGeR
Tigger is offline Find More Posts by Tigger
Old Jun 27, 2002, 05:33 PM
Red wings is offline
Find More Posts by Red wings
Joined Feb 2002
I just put one in a wattage Hawk and will be trying it this weekend. Easy install!!
Red wings is offline Find More Posts by Red wings
Old Jun 27, 2002, 07:28 PM
Joined Feb 2002
Old Jun 28, 2002, 11:03 AM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Twister
I have been flying an Astro 010 powered CSD Twister for almost a year now with hundreds of flights on it. It is a great small, fast, sport plane and the Astro power system is well matched to the plane. Here are the specs:
My current power setup is the following:
Astro Flight 16 turn 010 brushless motor
Castle Creations Phoenix-10 ESC
10-600AE Sanyo NiCds
APC 4.75x4.75 prop
Data from The Electric Motor Calculator (P-Calc)
Current = 7.018 amps
Watts Out = 60.85 watts
Eff = 73.9 %
Pitch Speed = 80.3 mph
Full Throttle Duration = 5:08 minutes
In real world testing I get over 7 minutes of flight time at full throttle so the average current must be around 5 amps.
JohnM is offline Find More Posts by JohnM
What pattern plane for an Astro 010 ? compuatic Parkflyers 9 Sep 17, 2004 08:57 AM
What is the best plane for an Astro 010 DIRECT drive? Clayton Parkflyers 2 Jan 23, 2002 04:30 PM
What is a good sport plane for an Astro 050 brushless? Clayton Electric Plane Talk 7 Aug 03, 2001 02:43 PM
Foamie for an Astro 010???? Don Sims Foamies (Kits) 6 Jun 23, 2001 03:48 PM
Prop for an Astro 010 Jim McPherson Parkflyers 1 May 14, 2001 04:31 PM
