Old Apr 16, 2002, 02:35 PM
grr1941 is offline
Find More Posts by grr1941
Newark,Ca
Joined Mar 2001
Cnc Foam Cutter
I THOUGHT SOME OF YOU MIGHT LIKE TO SEE THE
4 AXIS FOAM CUTTER I BUILT,
HOBBYCNC.COM 4 AXIS FOAM CUTTER KIT FOR MOTOR/ ELECTRONICS, $124.00
GILLES MULLER FRENCH SOFTWARE TO RUN IT. WORKS GREAT $30.00 (FREEWARE) 30 DAYS
grr1941 is offline Find More Posts by grr1941
Old Apr 16, 2002, 03:25 PM
grr1941 is offline
Newark,Ca
Joined Mar 2001
PHOTOS TOO BIG
I AM TRYING TO REDUCE THE FILE SIZE
OF MY PHOTOS ... SHOULD HAVE SOME DONE
ON WED I HOPE
GARY
Old Apr 17, 2002, 07:53 AM
grr1941 is offline
Newark,Ca
Joined Mar 2001
CNC PHOTOS I HOPE
I CUTDOWN THE PHOTO FILE SIZE
I HOPE THIS WORKS
Old Apr 17, 2002, 07:55 AM
grr1941 is offline
Newark,Ca
Joined Mar 2001
MORE CNC PHOTOS
MORE
A CLOSE UP OF THE WIRE GUIDE
THE BOW IS .8 DIA CARBON FIBER TO KEEP THE
WEIGHT DOWN ON THE STEPPER MOTORS . I BOUGHT
THE TUBE FROM AEROSPACE COMPOSITES.
Old Apr 17, 2002, 07:56 AM
grr1941 is offline
Newark,Ca
Joined Mar 2001
CNC PHOTOS
LAST ONE
.250 TEFLON BALL WITH .013 DIA HOLE AS WIRE GUIDE
.008 DIA WIRE , THIS LETS THE WIRE SLIDE WITH NO
LOAD ON THE BOW ,REQUIRED IF CUT TAPERED WINGS,ETC
TOO MUCH TIME SHOULD BE BUILDING
Old Apr 17, 2002, 09:46 AM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
That is some beautiful aluminum work.
Lets see it in action!
frankenfoamy is offline Find More Posts by frankenfoamy
Old Apr 17, 2002, 10:22 AM
Duke58 is offline
Find More Posts by Duke58
Cal Slope Criminal@DV
Duke58's Avatar
Hayward, CA
Joined Apr 2001
Very clean looking work Grr, I'm in Hayward ,want to cut me some cores? I have some Litho camera stuff I've been hacking on to maybe make a 3 axis router but I havn't gotten beyond the hacking stage yet.
Duke58 is offline Find More Posts by Duke58
Old Apr 17, 2002, 11:08 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Well done.. fabulous piece of workmanship.
Now that it's built what's it actually for??
Lotsa hardware for merely chewing up a piece of DOW Insulation ;-)
Only use I've ever seen that actually required a CNC foam cutter was the individual rib section/incidences for Alfons G's Horten IV...
Bare is offline Find More Posts by Bare
Old Apr 17, 2002, 12:12 PM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
Nice work!
Tell us a little more about it. What's the computer interface look like? What software do you run to generate the airfoils.
Carl Petersen is offline Find More Posts by Carl Petersen
Old Apr 17, 2002, 12:30 PM
mralston is offline
Find More Posts by mralston
Woodbridge, VA
Joined Dec 2000
Gary,
WOW! That's really slick! Did you make the linear slides, or are bought from somewhere?
Mark
mralston is offline Find More Posts by mralston
Old Apr 17, 2002, 01:15 PM
PoolMaster is offline
Find More Posts by PoolMaster
South San Francisco
Joined Apr 2002
I saw it work!
I saw the CNC foam cutter of Grr1941 and it works so nice. I have never seen foam cores cut so precisely; not even from commercial kits.
Congrats Grr.
...so there is a small glider I designed a small slope glider. It has foam core wings. I was wondering if you could...
PoolMaster is offline Find More Posts by PoolMaster
Old Apr 17, 2002, 03:59 PM
grr1941 is offline
Newark,Ca
Joined Mar 2001
LINEAR EXTRUSION
MRALSTON... I MADE THE AXIS WAYS FROM
THIS ALUM EXTRUSION
DELRIN BASE AS SHOWN 1/4-20 STEEL ROD IN A
OIL LITE BUSHING . DORLEC CORP. IN NJ
MAKES THE EXTRU.
Old Apr 17, 2002, 06:29 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
This looks great! I've kicked around the idea of building one myself. Seeing your's is a great inspiration, thanks!
GregG is offline Find More Posts by GregG
Old Apr 18, 2002, 08:30 AM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
selling them?
What are the odds you will make a sell a few of them?
I'm currently building the MM2001 cnc interface, and will need the mechanical part soon, your's is, by far, the most impressive set up I've seen.
Paul
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
CNC foam cutter electronics kit--anyone interested? fregon45 Foamies (Kits) 14 Jun 11, 2008 12:02 PM
CNC Foam Cutter Update. Photos posted fregon45 Foamies (Kits) 4 Jun 18, 2003 05:48 AM
How does a CNC foam cutter do tapered wings? Barrett Foamies (Kits) 5 Aug 02, 2002 11:28 AM
CNC foam cutter...I need some help. JayParke Power Systems 16 Apr 22, 2002 08:36 AM
Electronics kit for CNC Foam cutter--Anyone interested? fregon45 Power Systems 1 Mar 07, 2002 10:14 AM
