Old Jan 10, 2002, 07:55 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Gearbox Construction Techniques
Ralph, Jun, and others have posted details about building gearboxes in other threads. On Ralph's advice, I've purchased servo gear sets. As he found, the JR gear sets provide quite a few gears that are compatible with the Kenway gears. I'll post details about which gear set part number and what you get later. I didn't have much luck with Futaba gear sets providing gears that are compatible with Kenway gears. As soon as my order from Dave Lewis comes in I'll have a reasonably good starter set of the WES gears and the 2mm and 1.5mm id bearings.
But, I have questions. I thought I'd start by reposting Jun's gearbox making technique. I've replicated the part of rolling paper by using grocery bag paper. What I haven't been able to do is find any plastic tubes from liquid soap dispensers large enough to take the 5mm od bearings I get from Dave Lewis. Jun, could you tell me what size bearings you use, and what brand liquid soap has the right size plastic tubes (otherwise I'm going to be getting some strange looks in the grocery store). Also, it would be great if you could post the picture of your gearbox here again.
Dave Lewis is including plans for a two-stage gearbox in with my order, and I think I have sufficient gears to attempt one. I'll post details here on my progress.
Ralph, please jump in with whatever techniques you've learned.
Jun Nolasco quote from KP-00 vs KR1 thread
For the motor mount, I use rolled calling card paper 3/8" wide. I roll the paper around the motor for 1 1/2 to 2 loops, putting some thick CA on the overlap (normal glue or paste will also work just fine). I make sure the motor has a loose fit on the rolled paper. I then remove the motor and saturate the roll with thin CA and leave to dry. This gives me the ability to replace motors at will.
For the plastic tube, I use the ones normally found inside lotion and similar bottles. The ones I have work great on 5mm and 6mm outer diameter bearings. In fact, my wife even saves them for me.
You can also use rolled paper for the tube, built similarly to the motor mount described above.
For the spacer, I use a slightly thicker piece of balsa. I put a bit of thick CA on both sides and sandwich it between the motor mount and bearing tube. I then press on the fully assembled contraption until I achieve the proper gear mesh. I then tie several loops of unwaxed dental floss around the whole thing to keep everything in place. Finally, I remove the motor with pinion, bearings, shaft with spur gear, and saturate the dental floss and balsa spacer with thin CA.
Once things have dried, you end up with a very light but strong gearbox. I have yet to break any of the ones I have built.
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jan 10, 2002, 10:17 AM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
The white tube holding the bearings is a piece of a Bic pen.
DNA is offline Find More Posts by DNA
Old Jan 10, 2002, 05:37 PM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Gordon
I seem to think, fact I'm pretty sure the poly tubes you want are from those gallon containers of orange based abrasive hand cleaner. GoJo makes these products I want to call this stuff agent orange, but....???
Looee
Looooeeee! is offline Find More Posts by Looooeeee!
Old Jan 10, 2002, 10:24 PM
nolasco is offline
Find More Posts by nolasco
nolasco's Avatar
New York, NY
Joined Dec 2000
Gordon,
I have looked at all lotion and liquid soap dispensers here at home to figure out where the plastic tubes really came from. Unfortunately, the only thing I am sure about is where they did not come from. It's certainly not Vaseline, St. Yves, or Soft Soap. But, my wife says they most likely came from Bath and Body Works liquid soap dispensers. In any case, I use those tubes on 6mm outer diameter ball bearings. Funny thing though is that some tubes are a tight fit while other are loose.
For 5mm outer diameter ball bearings, I use the tube that comes with those toy propellers found in my LHS.
Here is a photo of another of my gearboxes. It works for DC5-2.4, N20, and GWS motors using 48 and 50-tooth spur gears and 9 and 10-tooth pinions. Other gear ratios might also fit.
Jun Nolasco
nolasco is offline Find More Posts by nolasco
Old Jan 10, 2002, 10:31 PM
nolasco is offline
nolasco's Avatar
New York, NY
Joined Dec 2000
Oops! Here's the image.
Jun Nolasco
Old Jan 11, 2002, 06:50 AM
Boston, Mass
Joined May 2001
DNA, thanks for the Bic pen tip. I've already cut one up and it looks like it will work.
Jun, thanks, this will give my wife an excuse to visit Bath & Body Works.
Looee, hmmm, Agent Orange ...
Old Jan 11, 2002, 07:48 AM
Pekka Mattila is offline
Find More Posts by Pekka Mattila
nothingtosay
Finland, Espoo
Joined Oct 2001
agent Orange
I Think that it's the stuff called Fast Orange
Pekka Mattila is offline Find More Posts by Pekka Mattila
Old Jan 12, 2002, 06:39 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
I know this isn't a gear box but will a O ring box do?? I was playing around and can up with a belt drive on the cheap Johnson motor. The belt drive works good but I'm not happy with the motor yet, to many amps and no poop.
I made the pulleys out of 1/8" Plexiglas cutting the "v" with my drill and a rat tail file. I press fit to the shaft. The shaft is in a CF tube. 3/1 ratio.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Jan 12, 2002, 08:25 AM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
Arizona Chuck
Looks nice, how do you cut the perfect circles?
Philip
fill is offline Find More Posts by fill
Old Jan 12, 2002, 09:13 AM
aeronutz is offline
Find More Posts by aeronutz
Leicester England
Joined Jun 2001
Belt drive
Is not as effecient as gears but it is really quiet
On little motors we used the ortho bands which are like mini rubber bands
Pullies - Guess who has a metal working lathe,
aeronutz is offline Find More Posts by aeronutz
Old Jan 12, 2002, 09:20 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Re: Belt drive
I do!
How much less efficient than gears do you think it is? I still have a belt drive in mind for pagers since a 2-stage gearbox will also suffer from efficiency losses.
Michael
epilot is offline Find More Posts by epilot
Old Jan 12, 2002, 10:02 AM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Re: Re: Belt drive
Michael
Don't know, but I'd say it's caused by belt slippage, and the additional side loads on the pulleys/bushings from the tension in the belt.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Jan 12, 2002, 03:48 PM
Old Desert Rat
Rimrock AZ. USA
Joined Mar 2000
fill,
I drilled the center hole first and draw the circle with a compass then carefully cut them out with a scroll saw. Then I chucked it in my hand drill and held it against the belt sander to round it.
Old Jan 13, 2002, 07:06 AM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi,
be sure to wear SAFETY GLASSES when turning plexiglass pulleys with your power drill! I once had to wait several hours in the emergency ambulance until somebody pulled a small piece of plastic out of my eye. Not mentioning that that hurts, at least that is time wasted that could better be used to build models!
jberg is offline Find More Posts by jberg
Old Jan 13, 2002, 01:35 PM
aeronutz is offline
Leicester England
Joined Jun 2001
Super gearing
Yes, you can have big gear ratios and if the power you are transmitting is small anyway there is not too much loss because of the sideways thrust on the bearings caused by the belt tension.
Andrew H gave me some silicon plastic tube which fits over the 1mm motor shaft, the ortho band seem sticky so I dont think there is much slipage going on.
I think this would better suit pager motors at hi revs and low power, so if the little pully is say Dia, 1mm and the biggy is say eh, 20mm what is the gear ratio?
20 to 1 sounds about right?
If it is a tight fit in your plane, 'turn the motor round' so the big pully is nearer the tail end.
My test one used a plasic pully made from a wheel thing I found in a craft shop, this was my uncivilised pre-lathe era!
What we need is someone clever like Andrew H, who as luck would have it will be testing a four engine micro plane on Saturday which is destined to have four highly geared pagers in it.
I was designing a super effecent carbon prop today too .... its all starting to come togther again
Mark
Mark
Ps Dr Chris has a lathe too, and some pagers.
Hull construction techniques? RGinCanada Scale Boats 48 Oct 24, 2006 11:11 AM
Tail Construction Techniques? turbodriven The Builders Workshop 12 Aug 06, 2005 12:14 PM
Construction techniques --may be off-topic byrocat Pusher Prop Jet Models 2 May 02, 2005 06:08 PM
Li Po Pack construction techniques gtstubbs Batteries and Chargers 41 Nov 03, 2003 07:42 AM
3D elevator construction techniques Protocooler Slope 14 Aug 30, 2003 03:23 PM
