Old Dec 12, 2001, 06:27 PM
tim_j-rome is offline
Find More Posts by tim_j-rome
tim_j-rome's Avatar
Toronto, Ontario, Canada
Joined Dec 2001
Yippee!
Save those Props!!!
I have just found a way to make a cheap and easy prop saver. All you need is a small four arn servo arm (with two of them cut off), two small elastic bands, and a prop! (oh...and of course that beloved GWS gearbox). Just follow the pics below. If you have any questions, just write back.
tim_j-rome is offline Find More Posts by tim_j-rome
Old Dec 12, 2001, 06:29 PM
tim_j-rome's Avatar
Joined Dec 2001
pic
here you go.
Old Dec 12, 2001, 06:30 PM
tim_j-rome's Avatar
Joined Dec 2001
pic3
here...
Old Dec 12, 2001, 06:36 PM
tim_j-rome's Avatar
Joined Dec 2001
This is what happens when the prop hits something
no broken prop!
Old Dec 12, 2001, 06:39 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Smart ideal.
But I would like to suggest to let servo-horn to be more deep inside to shaft. So you still can put GWS soft rubber spinner to protect someone be hitted.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Dec 12, 2001, 08:06 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Excellent!!!!!
Took all of 5 minutes to do. It helps to have a son in braces!
He sure looked at me funny when I said "give me about half a dozen of your rubber bands"
Maybe that $4000 was worth it... I get free rubber bands for my prop savers!
Gene Bond is offline Find More Posts by Gene Bond
Old Dec 12, 2001, 08:08 PM
tim_j-rome's Avatar
Joined Dec 2001
prop saver
lol...i'm glad to hear it went together well. Let me know how it works out for you.
Old Dec 12, 2001, 08:38 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I also hacked about 3/8" off the end of the shaft with my dremel. I left enough to get a GWS prop on there, but not an APC -- Bet that make Mr Lin Happy
Also, I leave the spinner off, in case I hit a little kid in the head, I want it to stick, so He won't trip over it when running to his mommy crying! I am after all concerned with his safety. Wouldn't want him to twist an ankle or anything!
Old Dec 12, 2001, 10:54 PM
Wilbur is offline
Find More Posts by Wilbur
Joined Sep 2001
Cool Idea!
If you use a oversize washer on the outside of the shaft
you give the prop more surface area to rest on making it
spin a little truer.
If you use a large enough control horn you can mount
even the APC E props
Wilbur is offline Find More Posts by Wilbur
Old Dec 12, 2001, 11:30 PM
Bleriot is offline
Find More Posts by Bleriot
Bleriot's Avatar
Joined May 2000
IMPROVISATION GURU
Well done. In 2 or more years of these motors in operation, here comes a new member ,Welcome to the Ezone Tim,and devises some very useful device without resorting to sheet steel/brass/aluminum, cutting, drilling etc, using something we all have some spares of. Great Idea, I vote this guy gets nominated for the best idea 2001 in the Ezone Hall of Fame (do we have one yet?) there goes the GWS prop saver $$$ Mr Lin unless you can make cheaper? Best Regards
Bleriot is offline Find More Posts by Bleriot
Old Dec 12, 2001, 11:43 PM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Dittos on what Bleriot said.
FANTASTIC!
Way to go Tim!!! Thanks!
Anything else you have to share Tim?
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Dec 13, 2001, 09:41 AM
tim_j-rome's Avatar
Joined Dec 2001
WOW!!!
hey guys, thanks for all of the compliments. I'll try that idea about the bigger washer on the end of prop shaft. Thanks again
-->Tim
Old Dec 13, 2001, 10:12 AM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
There's an article on rcmicroflight on this, but suggesting cutting/shaping/filing a small thin piece of brass. Must admit that the servo horn is a much easier approach. The article also suggests cutting the shaft so that only 0.085" of the threaded portion still shows. Probably need a little more for the tickness of the horn. Keeping the prop closer to the gearbox should minimize any unwelcomed vibration.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Dec 13, 2001, 12:21 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Here is another method that could be used on the GWS drive as well. Its just a piece of piano wire, paper clip etc. bend to fit through the holes in the gearwheel and having the ends bent to form hooks. Of course you would have to shorten the output shaft.
Michael
epilot is offline Find More Posts by epilot
Old Dec 13, 2001, 02:13 PM
Newark, DE USA
Joined May 2001
Hi epilot,
Also very cool.
Youse guys is sumppin".
RB
Discussion Friendly Reminder - be careful with those props ImaBiggles Power Systems 2 Dec 30, 2005 02:13 PM
Download Save those Blades contact303 Micro Helis 5 May 10, 2005 05:20 PM
Save Those Old Credit Cards...! Boss248 3D Flying 20 Aug 06, 2004 11:31 PM
Whoops! How can I save those EPS-3xxC motors? llrelease Power Systems 9 May 16, 2004 09:31 PM
Save those hard-disk platters.....make great motor plates and mounts pullin-gs Power Systems 2 Jan 28, 2004 08:03 PM
