Closed Thread
Old Dec 31, 2003, 06:26 PM
RCL
RCLanding.com
RCL's Avatar
Batavia, Ohio
Joined Nov 2003
Part 8?
PART EIGHT!?!?!?!?
You got to be kidding!!
Part 8??????
This is unbelievable!!!!
Congrats Tim!
How can a couple slabs of foam do this? I lay awake nights just thinking about it. I can't sleep... the clowns will eat me!
RCL is offline Find More Posts by RCL
Old Dec 31, 2003, 06:29 PM
RCL
RCLanding.com
RCL's Avatar
Batavia, Ohio
Joined Nov 2003
I ordered EPP foam today.
Can you say R & D?
Happy New Year everyone!
Mark
RCLanding.com
Old Dec 31, 2003, 06:41 PM
layne's Avatar
Louisiana
Joined Oct 2003
EPP
Say , is there a Good place to order the epp , from , cheap and do they have different colors ??? Layne
layne is offline Find More Posts by layne
Old Dec 31, 2003, 07:02 PM
RCL
RCLanding.com
RCL's Avatar
Batavia, Ohio
Joined Nov 2003
I'm not really sure. I haven't tried to get colors or cheap. The only thing this place had was thick slabs of white that need to be cut into sheets thin enough to use. That's all I need to do a little research. I think there's another place selling thin sheets, but I don't have any references.
If you want thick stuff, try www.rpvi.com
Mark
Old Dec 31, 2003, 07:57 PM
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
Re: EPP
mark at FunPlanes.com sells 4mm and 6mm thick sheets of epp in 3'x2' and his prices are very reasonable (and
he ships internationaly, lucky for me ), if you require some of these or different sizes PM him through this
forum i'm sure he'll set you up with what you need .
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Dec 31, 2003, 09:42 PM
40%, 5% whats the diff?
TeamSME's Avatar
Baltimore Greenbelt, Maryland, United States
Joined Jul 2003
4 pieces of foam. And plans,,,
Sean
TeamSME is offline Find More Posts by TeamSME
Old Dec 31, 2003, 09:55 PM
Burnin' holes in the sky!
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
FYI, EPP is absolutely nothing like EPS (duh!) It has zero rigidity, so a flat plate is almost out of the question. You could either cover it to give it some strength, or put a ton of spars in there. I don't know if a higher density would be a lot stiffer as I've only had experience with 1.3 lb/sq. inch. You may think that the ability of EPP to fold instead of crack is a good thing, until your wings flapping like an ornithopter make tracking/precision impossible! I would suggest going with a wing like the SX2 has.
Of course I'd love to be proved wrong, but take this as a warning.
Dan
SkyPyro is offline Find More Posts by SkyPyro
Old Jan 01, 2004, 06:06 AM
RCL
RCLanding.com
RCL's Avatar
Batavia, Ohio
Joined Nov 2003
Another FYI...
The 1.9 d is stiffer, but I don't think it's enough to work like depron. Some thread was mentioning it's use for a fuselage because it was stiffer. But then, that fuse bent right in half like the SX2, so it can't be too stiff. I think you're right about using other things when trying to obtain stiffness. ...either built-up or spars or something.
Old Jan 01, 2004, 10:30 AM
fix-it-up chappie
tolladay's Avatar
Valley Village, CA
Joined Jan 2002
Why not try building the wing like Didier's Funtana? http://www.rcgroups.com/forums/showt...0&pagenumber=1
I think it's built in 3 layers; 3mm foam with a 3mm balsa and CF center section. If the EPP doesn't stretch much then this might work.
Of course, not having the stuff in front of me means I'm just wild guessing.
For all those who observe; Happy New Yewar.
tolladay is offline Find More Posts by tolladay
Old Jan 01, 2004, 01:55 PM
Forest's Avatar
London
Joined Dec 2003
Thanks for the advice Aero. Will let you know how I get on.
Forest
Forest is offline Find More Posts by Forest
Old Jan 01, 2004, 04:27 PM
Tromso, Norway
Joined Nov 2001
Originally posted by birdie_in_texas
does that really say -15..? omfg...
Yes it does read -15 Celsius, man was it cold. It was nice dough to get together and fly though. It was a nice atmosphere it the special light, se photo.
At the positive side, the Lipos didn’t hold up as good as in warmer conditions so I could use more of the throttle stick. It was more pleasant to fly in that manner. I am thinking on propping down so more of throttle can be used under normal circumstances. More that 2:1 thrust is much more that what is useful. Am I onto something or will I get disappointed?
ewikran is offline Find More Posts by ewikran
Old Jan 01, 2004, 06:24 PM
fix-it-up chappie
tolladay's Avatar
Valley Village, CA
Joined Jan 2002
ewikran,
You flew in that? Wow! My respect for Norwegians just went up a couple of notches.
Why not prop down? As long as you have the vertical you want/need. As an added bonus, you'll also get longer flights.
At 2:1 thrust you probably have enough extra power to add a small IC enigine and use it to run a heater to keep the li-polys warm. Kind of like a
"hybrid" (gas/electric) car.
Old Jan 01, 2004, 09:28 PM
korundal's Avatar
macon, georgia
Joined Jun 2002
my 3DX Razor 400
Had the maiden flight 3 days ago.
Blue FFF
Gws D gearbox
12x6 SF
AUW 11.83 oz
Razor 400 ( got it in June at SEEF)
3s 1200 Etech
4 HS 55
Hope to learn the 3D stuff on this plane before I bust up the Tantrum.
Great plane Tim H.
korundal is offline Find More Posts by korundal
Old Jan 01, 2004, 09:39 PM
korundal's Avatar
macon, georgia
Joined Jun 2002
My fist plane with no landing gear. Was somewhat apperhensive
about landing, but this plane really slows down for a extra soft touchdown.
Construction mistakes
dont use hot glue on the control horns( I was in a hurry)
on the secont flight noticed the roll rate was way off
the right aerilon zip tie connection was loose.
Mounted the wing 1/2 inch too far back. Need to Sudy the plans
better next time.
Closed Thread
3D Fan Fold 3DX, Ultimate Bipe and Yak54...V9 Martin Hunter 3D Flying 524 Feb 04, 2004 08:19 PM
3D Fan Fold 3DX, Ultimate Bipe and Yak54...V7 Martin Hunter 3D Flying 522 Dec 31, 2003 06:01 PM
3D Fan Fold 3DX, Ultimate Bipe and Yak54...V6 Martin Hunter 3D Flying 541 Dec 14, 2003 01:22 AM
3D Fan Fold 3DX, Ultimate Bipe and Yak54...V5 Martin Hunter 3D Flying 520 Nov 25, 2003 05:32 PM
3D Fan Fold 3DX, Ultimate Bipe and Yak54...V4 Tim H. 3D Flying 718 Nov 10, 2003 12:11 PM
