Old Jan 18, 2004, 06:31 PM
Art Newland is online now
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
I put an amp meter on the cdrom motor and it's only pulling 3 amps. Looks like it could pull a lot bigger prop, maybe even a Piccolo MR?
Art Newland is online now Find More Posts by Art Newland
Old Jan 18, 2004, 11:39 PM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
Sounds like a perfict EDP50 brushless replacement motor.Rewrap it to 28 turn of 30gage and you have a 3s pack brushless micro heli tail motor replacement and at less weight.Matt
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Jan 19, 2004, 02:51 PM
CD-ROM Junkie
Joined Apr 2001
Hey Matt,
I stopped by a local computer store and bought a couple of used CDROM's today, one has grey magnets and ball bearings!
Old Jan 19, 2004, 04:47 PM
Joined Oct 2003
Great find,if its about 16grams you can safely pull 12 to 14 amps with a 4x4 prop with that motor.About speed 400 power.Goes great on a 6oz mini wing.About 100mph.Give it a shot.Matt
Old Jan 19, 2004, 09:33 PM
CD-ROM Junkie
Joined Apr 2001
Here we go, home made Piccolo Brushless Power
Gleened a nice CDROM motor today and have started to see if I can convert it for use in my Piccolo. Here are the parts after removing from the drive and removing the old windings.
Old Jan 19, 2004, 09:37 PM
CD-ROM Junkie
Joined Apr 2001
Making a longer shaft
The bearings and motor could be used as-is with a small mount fabricated out of wood, but I need a longer shaft since the power will be transmitted out the bottom to a gear. Here are the parts for the shaft.
Old Jan 19, 2004, 09:41 PM
CD-ROM Junkie
Joined Apr 2001
I had to turn down the bearing tube so as to have a nice fit of the larger tubing. I chucked it up in my drillpress and with a small file, ground it down until I had a snug fit. The smaller tubing fits snuggly into the larger, a 8mm bearing fits perfect into the smaller tube.
Old Jan 19, 2004, 09:43 PM
CD-ROM Junkie
Joined Apr 2001
Assemble tube
I line it all up with the shaft and bearings, and silver soldered it together.
Old Jan 19, 2004, 09:44 PM
CD-ROM Junkie
Joined Apr 2001
I added a little red loctite to the outside of the bearings and put it togther to dry.
Old Jan 19, 2004, 09:46 PM
CD-ROM Junkie
Joined Apr 2001
Here is the shaft assembly from the side.
Old Jan 19, 2004, 09:47 PM
CD-ROM Junkie
Joined Apr 2001
Had to drive out the old short shaft.
Old Jan 19, 2004, 09:49 PM
CD-ROM Junkie
Joined Apr 2001
install the long shaft, which was also removed from the drive, one of the laser guides.
Old Jan 19, 2004, 09:50 PM
CD-ROM Junkie
Joined Apr 2001
I knocked the bell off of the hub! Wasn't to hard to put back on, used some more red loctite.
Old Jan 19, 2004, 09:52 PM
CD-ROM Junkie
Joined Apr 2001
Installed bell, took a while to get it back on straight, the're hardly precision to begin with.
Old Jan 19, 2004, 09:54 PM
Joined Oct 2003
Nice job Art,that should work.Have you come up with a 3mm pinion?Matt
Piccolo Flys Part V Art Newland Micro Helis 535 Aug 29, 2004 06:00 PM
Midget Piccolo Flys dulcelife Micro Helis 14 Aug 18, 2004 11:02 AM
Piccolo Flys Part IV Art Newland Micro Helis 507 Jul 22, 2004 05:45 PM
My new piccolo flys great!!! JStory Electric Heli Talk 3 Mar 22, 2002 09:51 PM
My Home-Made CP Piccolo Flys!!!:) Eco8gator Electric Heli Talk 2 Dec 21, 2001 11:52 PM
