Old Nov 12, 2003, 07:59 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
7.5mm brushless motor
This is my first BLDC motor with my own windings in it. I used large wire to prove the concept, that's why it's 7.5mm. Next try will come out closer to 6mm.
mcross is offline Find More Posts by mcross
Old Nov 12, 2003, 11:36 PM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
sweet Brushless where is the third wire?
AIR MOVER is offline Find More Posts by AIR MOVER
Old Nov 12, 2003, 11:53 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Nice.
How did you wind the coils?
Billy
billystiltner is offline Find More Posts by billystiltner
Old Nov 13, 2003, 06:47 AM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
AIR MOVER
There are acually all 6 wires coming out the back of this motor so I could run it as Y and Delta.
Billy
The winding is done similar to a coreless pager. The coils are put on a piece of tape and then wrapped around a mold. Technically it is a Brushless, Sensorless, Slotless, DC Motor.
Old Nov 13, 2003, 07:27 AM
Joined Nov 2002
Do you have a diagram of how they are wound?
I would like to rewind some of my broken ones with a different guage wire and different resistance.
Billy
Old Nov 14, 2003, 01:00 AM
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
sweet so you have them in two bundels of three gotcha man that must have been some tough doing with the wires being so small.. are you going to gear it or DD the motor? what are you going to do about a esc for this?
Old Nov 14, 2003, 07:00 AM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
AIR MOVER
Once I worked out the process it was relatively easy. I won't do anything with this one, it is way too hot and was only intended to prove the process. The next couple will be winding development, it may be some time until I have one to try on a plane. ESC I make will be on-off, however the motor will work with commercial BLDC ESCs. For a little more about the ESC I intend to build see Billy's thread on Micro Bushless Controllers.
Old Nov 14, 2003, 10:31 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Mike,
It sounds like you are doing good work. I know about working out the process. Keep it up.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Nov 14, 2003, 07:51 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Greebe
I guess if I "fed" it 3 phase AC at 5 or 6 volts it would run. So it must be an AC motor. Oh well,
back to the drawing board
Old Nov 14, 2003, 08:22 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I'm interested in the winding process is sounds like you make a flat coil and then make it form a tube by rolling but that isn't quite the same as a pager is it as that doesn't have a seam or have I got this all wrong and you wind around(and through) a cylinder?
What about French knitting or braiding a winding
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Nov 15, 2003, 02:10 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Yeah I catch myself calling them DC motors too at times. Funny how they're driven by an amplifier without ground reference from a DC source that messes with our heads so easily
AC motors operate on fixed frequency sine wave voltage sources. This is not the case with our Brushless DC motors.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Nov 15, 2003, 07:31 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
All motors operate on AC. A commutator is a mechanical inverter, reversing the polarity of the windings as it switches.
You are all correct.
Don't feel bad, we have the same debate in the industrial world. Brushless DC = Permanent Magnet AC...
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 15, 2003, 06:11 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Winding diagram
Here is a very crude drawing of the way I make the windings for my BLDC motors. I believe most coreless pagers are done flat and then rolled around the comutator piece. All the 6 or 7 I took apart had a slight gap or misalighment at one of the termination points.
Each phase contains 2 coils wound in opposite directions. There are 3 phases. The first is highlighted in pink on the sketch. The second is highlighted in yellow. The third is not highlighted.
When wrapped around the mold, the two coils from each phase are 180 degrees apart. Coils can be made in many ways, I wind them on an arbor the appropriate diameter and tie them with thread. The different diameters for the three phases is only for clarity on the diagram.
Old Nov 15, 2003, 06:26 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Here is a winding and the mold. The mold diameter is suficient to clear a magnet from a coreless pager motor. The pin sticking out the mold is the diameter to press fit the bearings from the same pager motor that gave up the magnet. The winding is normally not removed after taping to the mold but this one is no good.
With the winding taped on the mold back iron must be added. Rings made from a magnetic metal are best, but I don't have any. I have been using sheet metal wrapped around the winding in two layers. I then wrap some thread around the motor for a little extra strength and coat with epoxy.
Cover with shrink tube and let cure.
Old Nov 15, 2003, 06:32 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
After molding with shrink tube removed.
46 Gram Micro 3D with 7.7g Brushless Motor! bselman Scratchbuilt Indoor and Micro Models 141 May 05, 2008 04:50 PM
Sold MP Jet AC 28/7-30D Brushless Motor 44 NEW! $30 hsgreer Aircraft - Electric - Power Systems (FS/W) 1 Dec 04, 2006 09:58 PM
Help! Looking for a 7-cell brushless motor. crapula Power Systems 12 Apr 15, 2006 12:39 AM
MP Jet 28/20-7 outrunner brushless motor ptglass Power Systems 3 Feb 06, 2005 08:17 PM
Mega 16/7/12 brushless motor F/S jbrundt Aircraft - Electric - Airplanes (FS/W) 1 Apr 07, 2004 10:50 PM
