Nov 12, 2003, 07:45 AM
Boston, Mass
Joined May 2001
Michael,
You have to understand that this is about the 3rd metal object I've machined on my lathe. And at the time I did this one all I had was the crappy tools that came with the lathe, and no grinder to sharpen them on, or even cutting oil (used WD40 for cutting oil when doing this). Since then I've laid in a supply of tools and materials etc to machine with and from. This one is definitely a learning experience, and quite ugly. However, it runs!
Graham and I have intended to go for a 1mm or less air gap since the beginning. We know it makes a difference. But, without the magnets on hand, or the right size materials to machine from this is what was possible. I did not have solid rod then. And, the tubing I had allowed pretty much this size.
Billy,
From what I understand people like Schulze and Castle Creations and others worked a long time on the programming for their brushless controllers. Apparently the ability to start a motor that is not spinning, in a gentle manner, is quite difficult. The controller I'm using is sensorless, so no Hall Sensors. Magnets moving past a stator winding act like a generator and the controller monitors the increase and decrease in this voltage coming back from that wire and determines where the stator is positioned so it knows when to send a pulse of current. There's way more to it than that and I know I'll not be the person to write that code. Object-oriented statistical programming is more my area of expertise.
Gordon
