Old Oct 02, 2003, 12:09 PM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Micro Drenalyn
My JMP RX Combo and a pair of actuators arrived today. A real piece of artwork in itself.
I'm considering building a micro Drenalyn to put this lot in. Intending to use a single 145 Kokam and the KP00 2.67/1 with the U80 prop for power.
The big question is how big should the Drenalyn be? I've experience of the 380mm span version with an IPS which is amazing with a small 2s1p Lipo pack.
For those of you who don't know what I'm on about; Drenalyn
I've some 2mm Depron which I intend to use.
Dave
wildpalms is offline Find More Posts by wildpalms
Old Oct 02, 2003, 01:52 PM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
Dave... You could wiegh all the gear that you will be useing.. make the plane lil larger then you think it should be and put some wieght equal to your gear and test glide it .. you can cut it down till you find the best size for the gear you will be hauling through the air.
AIR MOVER is offline Find More Posts by AIR MOVER
Old Oct 02, 2003, 02:45 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Dave,
what about this one? It has a KP00-like drive which I took from a cheap free-flight plane, a GWS 3x2 prop and a self-made IR receiver. The span is 200mm, the weight about 25g. It uses one 145mAh Kokam cell. It is made from 3mm Depron.
It flies great if you balance the elevons well (they must not hang down). But better have quick reflexes!
By the way, that's a D cell for size comparison.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Oct 02, 2003, 02:57 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
Thanks Jochen, I just knew I wouldn't be the first I was just thinking 200mm might be about right.
My reflexes should hopefully be up to the job with all the hours on my micro heli lately.
Dave
Old Oct 02, 2003, 03:21 PM
jmquetin is offline
Find More Posts by jmquetin
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
Dave,
Our Horten wings "Variantes" 50 or 60 could also give you an idea of what you can acheive with a JMP-Combo, KP00 geared 2.7/1 and a GWS prop on one Li-Poly.
See my Web page http://jmquetin.free.fr/Variante.htm
Keep us inform on your Micro-drenalyn.
Regards.
J.M. Quetin
JMP-Team
jmquetin is offline Find More Posts by jmquetin
Old Oct 02, 2003, 03:57 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
Thanks for the link J.M., it was these babies that made me order the little JMP rx setup. I have in fact asked my Father to try and source a back issue of the magazine in question (my family all now live in France )
Some parts still required (plugs/sockets/fine wire etc) so progress will be slow.
200mm looks good, have already cut most of the parts
Dave
[edit]
Totally off topic but I see you into the Psion 3a PDA. I haven't used one in years but I did some bespoke development work on these a few years back.
Micro Drenalyn (300mm version, VERY SMALL) Acer Scratchbuilt Indoor and Micro Models 22 Apr 11, 2002 11:02 AM
Micro Drenalyn (12" wing span) Acer Parkflyers 1 Apr 06, 2002 07:36 PM
