At 10 cycles I never thought balancing was needed. That's why I'm hesitant to say that was the problem. I think the reason they blew was the factor of heat and rupture. A cool, ballooned cell will probably not be so violent. My pack was hot off the charger when I punctured it.
I have never taken the pack belon 3.2 volts per cell, but had been discharging at extremely high discharge rates. But again, it was well within recommendations by the manufacturer. Who knows??? I'm going out to buy one of the fireproof safes now. I really thought it overkill before this afternoon, now I don't. -Jim |
Walled Lake, MI, USA
Joined Feb 2000
>> I was charging right at the maximum charge level suggested by the manufacturer. This charge rate may have been too high, this is my current theory for failure as the last pack ballooned while charging at this same rate.
Jim, this is the first thought that struck me. There has been discussion of LiPo charging at greater than 1C. Some people have successfully done this. I've debated in my mind if it's really worth the risk. Your experience convinces me that, at least for the time being, it might be best if everyone sticka with 1C for LiPo charging. The issue of the violent reaction of the cell to being punctured is another issue altogether. My understanding has been that this is the proper way to prepare LiPos for their salt water bath prior to disposal. There must be some kind of variable here that has not occurred in similar situations. For instance, I recall Electroman warning about sticking a sharp object too far into a LiPo cell and causing a short. We're getting a lot of clues from all of these various incidents. But I don't think anyone has been able to add up all the clues and figure out what exactly is happening in the cases of violent failures that is not happening in the cases of "soft" failures. It only reinforces the fact that the use of Li-poly for e-flight is "experimental" rather than a proven technology. No one should be using these cells unless they fully understand this, and are prepared to take the safeguards required when using experimental technologies. EDIT: I see now where you said your cell was hot off the charger when you punctured it. I can't recall of Electroman had mentioned letting a ballooned cell sit for awhile before puncturing. In any case, we now know that puncturing a LiPo hot off the charger is not a good thing to do! |
What's even stranger is that the rupture where the flames shot out are on the other side of the pack. I punctured the cell on one of the flat sides in about the middle. Right after that the side of the cell opened up and the flames shot out. The very very small hole I made is still there, and just as small.
-Jim |
Joined Feb 2000
Jim, we just don't know enough about this to fully understand it. It's possible that the entry of cool air into the hot pack contributed to a failure that was already in the process of happening. Or it could be a complete coincidence of timing that the failing cell happened to let loose just as you were puncturing the covering on the other side.
We just all have to keep reading and trying to understand all of the details about all of these incidents, keep discussing them and keep trying to work together to figure out exactly what's happening. |
Hey Guys,
Keep in mind that Jim punctured these cells HOC. Everything I have seen about damaged Lipos suggests that you wait at least 20 minutes, or more, to verify that the damaged pack will not self ignite before doing anything else. I would not recommend taking a balloned pack HOC and doing anything with it until it cooled. |
| Thread Tools | |
| Discussion It's that time of the year again - Don't leave your lipos in the sun | rampman | Batteries and Chargers | 10 | Jun 07, 2007 01:30 PM |
| Discussion Don't Forget to Disconnect Lipos | E-Challenged | Batteries and Chargers | 1 | Aug 16, 2006 03:31 PM |
| Alert Don't get complacent with Lipos! They realy do explode | mikez104 | Power Systems | 47 | May 01, 2006 01:05 PM |
| Cool AMA didn't ban Lipos... don't worry. | e-sailpilot86 | Electric Plane Talk | 28 | Jun 11, 2005 10:04 PM |
| Balancing lipos that don't have taps | glide | Batteries and Chargers | 2 | Mar 06, 2005 04:57 AM |
