Old Sep 18, 2003, 12:34 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
source for mega gearbox pinions
I am referring to the larger mega gearboxes for the 22/30/x series of motors. I can't find a source for the pinions. I would like to change a 5:1 gearbox to a 4:1 or even a 3.5:1 Thanks for the help.
jay
soholingo is offline Find More Posts by soholingo
Old Sep 18, 2003, 12:53 AM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
If it's the planetary gearbox Jay, I don't believe you can change the ratio.
William A is offline Find More Posts by William A
Old Sep 18, 2003, 01:01 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
that is NOT what I wanted to hear... The ONLY way I can make the setup I have work is if I use a 20" folder with this motor... And 24 cells...
for what it's worth... I already broke the mega 22/30/2 in, using the traditional water break in method...
Old Sep 18, 2003, 01:10 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
lol, glad to hear your taking good care of your toys.
Old Sep 18, 2003, 01:18 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
3:1 too much ?
Old Sep 18, 2003, 01:23 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
3:1 would be fine, but mega only anounces the 3.5, 4, and 5 to 1 ratios. Well at least that's all I have been able to find.
j
Old Sep 18, 2003, 01:37 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Well, it just so happens that I've got a used VMG 3:1 that's not doing anything.
You could have it to your door for $30
Old Sep 18, 2003, 01:45 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Plus one condition....
Old Sep 18, 2003, 03:51 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
that's an offset gearbox right? And can it handle 700 watts? And will the pinion fit a 5mm shaft? Remember this is the bigger mega...
j
Old Sep 18, 2003, 11:15 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Yes, offset, rated at 600W, and 5mm pinion shaft.
Actually, 22 series is a 'mid' size, 45s are much bigger
I use to run it with a 22/30/3, 10 cells and a 16X14 I believe.
http://www.modelmotors.cz/index.php?..._odkazy=prevod
http://www.icare-rc.com/gearboxes.htm
Old Sep 18, 2003, 08:56 PM
tphillips is offline
Find More Posts by tphillips
Hey, I wanna fly too!
tphillips's Avatar
United States, TX, Justin
Joined Sep 2001
FWIW, I've used THREE of the VMG 3:1 at around 900 watts with a 20/30/2-18cells-13x8 3 blade which seemed to work fine. Why three GBs? Well the prop shaft is not hardened steel and will bend rather than break a Master Airscrew prop from a prop strike (yep, my fault). Two other unfavorable comments would be: 1) the main gear bell is attached to the motor adaptor with 2 screws located 180 apart, and all of mine would rock back-n-forth. Not great for the gear mesh. Fixed the problem by securing the GB and motor both. 2) The two main bearing are a press fit and some weak Loctite between bearings-to-housing and bearings-to-shaft. On all three GBs the shaft came loose. Once without notice allowing the main gear bell to wear against the pinion. And on one the bearings were loose in the housing too. Fixed with green 'shaft' Loctite.
Two of the VMGs could have bought one of the MEGA planetary that does have a hardened shaft. Would I buy another one? Yep, but only for a folding prop setup. The other issues are easy enough to address.
Terry
tphillips is offline Find More Posts by tphillips
Source for Mega L4 motor jolin Sport Planes 2 Jul 28, 2004 05:11 AM
Question What prop for mega gearbox ? foamster 3D Flying 2 May 01, 2004 04:36 AM
Source for GWS gearbox that fits AstroFlight 010? uglyplane Parkflyers 4 Dec 15, 2002 03:00 AM
WOW.. Cheap source for MEGA+CC ESC? FX1SUB Parkflyers 4 Nov 06, 2002 07:45 PM
source for 10 and 11t pinions for endo and gd600? DeaninMilwaukee Sport Planes 13 Dec 19, 2001 02:35 AM
