Old May 23, 2003, 10:10 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
My Little CNC mill
I mentioned this in the carbon prop thread and though a few of you might be interested.
I bought a small Proxxon manual milling machine, a tiny little thing but really nicely made and with a really fast spindle which is excellent for small cutters. I then added stepper motors and am building drivers to run it from my PC.
I started a webpage on it and will soon be updating when I find the time to complete the final soldering of the driver box.
Here's the link:
My milling machine
Working envelope is small at 2"X6"X2" but it can mill ali and brass.
Cheers,
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old May 23, 2003, 10:17 AM
Sticky Shepherd
Oxford/England
Joined May 2001
Please don't report me to the moderator, it is small and I do use it inside. If I throw it it flies, honest
Old May 23, 2003, 10:37 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Graham,
Very nice. Do you know if Tim plans to offer a conversion kit as well as carrying the machine (I suppose I should just email him)? Something tells me that Tim will be getting an order from me when next year's bonus is paid.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old May 23, 2003, 10:40 AM
cybermike is offline
Find More Posts by cybermike
cybermike's Avatar
Lincroft, NJ
Joined Feb 2003
That's cool - could probably do (small) PCB drilling with that too. I was looking at this http://www.harborfreight.com/cpi/cta...emnumber=40101 and thinking of a similar conversion.
Mike C.
cybermike is offline Find More Posts by cybermike
Old May 23, 2003, 10:42 AM
jnowell is offline
Find More Posts by jnowell
jnowell's Avatar
United States, FL, St Petersburg
Joined Sep 2000
Graham,
That's cool, but we want flying pics I hope you don't have to kick yourself off E-zone
I'm setting up a CNC hot wire cutter right now, but the controller board was already built. I wish I could build one myself...
Jason
jnowell is offline Find More Posts by jnowell
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
very nice Graham,
We wont report you to the Mods if you make some cool stuff for us to drool over
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old May 23, 2003, 11:10 AM
Sticky Shepherd
Oxford/England
Joined May 2001
Cheers guys.
Gordon, you only need to cut some alumnium plate to make adapter plates. I can supply my drawings for that if you wanted. Easy to do on that mill of yours.
Mike, pcb drilling should be fine, again the high speed spindle is good for small drills. There are quite a few mills worth converting out there, the one you show might be a little flimsy for precise work, rigidity is everything, actually small stuff is good for that.
Jason, I now wish my drivers had been ready built. That said the cost of an additional axis for the Camtronics 3 axis system makes it a little expensive. There is another nice three axis driver that does upto 2.5amps and higher volts from www.xylotex.com they also do an additional axis. I am guessing you got a all in one 4 axis job.
Cheers,
Graham
Old May 23, 2003, 11:43 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Mike C.
Mike, save up some more bucks and by a proper mill. That thing is pretty useless for anything other than wood. The Sherline mill is a much safer bet for a CNC conversion, albeit more expensive. It is a proper machine tool, the one in the link is more of a toy.
Michael
epilot is offline Find More Posts by epilot
Old May 23, 2003, 11:54 AM
cybermike's Avatar
Lincroft, NJ
Joined Feb 2003
Michael - thx - I was afraid of that. Like the Dremel add-ons - not terribly precise. I will avoid & pass it along to a friend that's contemplating one.
Mike C.
Old May 23, 2003, 12:24 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Very Cool. One question, though. Is it a true CNC mill? If so what on earth are you using to create your NC sequences? I ask because I have a copy of Pro/E Wildfire (work) and know how much it and its ilk cost.
Comatose is offline Find More Posts by Comatose
Old May 23, 2003, 02:09 PM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
That is so cool Graham.
How long before you make micro turbines .
How much did it cost to get the whole machine done (including motors etc?
Josh
j8m8l is offline Find More Posts by j8m8l
Old May 23, 2003, 02:14 PM
Boston, Mass
Joined May 2001
Graham,
How hard is it to remove stepper motors and go back to hand wheels? What worries me is that once converted to CNC that I wouldn't be able to do a quick hand machining task. Also, if this mill is so inexpensive, by the time I buy all the other stuff to CNC it, is the cost of the mill a small part of the entire package (motors, software, etc)? I don't really know yet. And, I'm trying to learn how to use what I have. But, at 100 pounds, mine is not as cute a table top mill as yours. Still, maybe I should think about converting it at some point. I could machine huge props.
Gordon
Old May 23, 2003, 03:01 PM
epilot is offline
epilot's Avatar
Joined Nov 2000
Gordon, those look familiar. I have exactly the same mill and lathe. If you search the net there are several sites that show the mini-mill converted to CNC where the handwheels can still be used.
Michael
Old May 23, 2003, 03:45 PM
Boston, Mass
Joined May 2001
Michael,
So, I'm in good company. If you come across any of the sites that show the conversion, could you email them to me?
Now we need Jochen to get one each of these.
Gordon
Old May 23, 2003, 04:26 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Michael and Gordon,
I have been looking at this stuff for a long time. I did not know yet what to save money for first (mill or lathe) and end always up spending the money otherwise ... .
I thought of buying the Proxxon BFW40/E mill system with the BFW2000 drill stand because I already have the cross table KT 150. That stuff looks strong and is not too expensive.
But I also do not want to divide my time too much between building a CNC extension to a mill system and building planes (although it is quite interesting, and I would like to *have* a CNC system)- all these decisions!
I second Michaels opinion about the simple '6-in-one' mill and lathe system - this is a toy IMHO, I have one, an old, used system, gotten as a gift.
Regards, Jochen
jberg is offline Find More Posts by jberg
Discussion My CNC mill for RC projects and Hotwire built from scratch kfong The Builders Workshop 32 Apr 25, 2010 01:56 PM
Looking for CNC Mill Part I PanzyPoof The Builders Workshop 2427 Feb 09, 2005 07:26 PM
My little Lightning Light Danny Troy Scratchbuilt Indoor and Micro Models 4 Sep 21, 2002 03:06 PM
My neighbor has a CNC mill and a Laser Cutter!!! JStory Electric Heli Talk 1 Dec 01, 2001 07:42 PM
