Old May 15, 2003, 12:09 PM
BigDave is offline
Find More Posts by BigDave
Eat, sleep and FLY
BigDave's Avatar
Conway, Arkansas
Joined Dec 2002
Li cells can cause a fire
It's my fault... But beware!
This is a word to the wise. If you charge a two cell Li battery with the charger set on three cells, a disaster can result. I am not blaming the battery or the charger this was a pure lack of attention. Nevertheless, the fire that resulted could have been avoided if the battery had been charging in a fire-resistant container.
The battery launched itself off of my charging bench, disconnected itself from the charger, and landed on the carpeted floor where it spewed hot contents onto the carpet and started a fire. I was able to extinguish the fire but some damage was done to my hobby room and a couple of planes went up in smoke.
It would be very wise to put Li packs in a fire proof container when charging and not just on a fire resistant surface. I would HIGHLY suggest placing them inside something similar to a Pyrex bowl with a Pyrex lid.
I like the packs, like the performance, and I won't be without them. But, be CAREFUL when charging.
I wonder if my wife will miss her big casserole dish?
BigDave is offline Find More Posts by BigDave
Old May 15, 2003, 01:01 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
There were discussions here a few months ago about similar incidents. Sorry that you didn't have a chance to see them and learn about this potential problem before your accident. Thankfully, no one was injured and it sounds as if you were able to keep damage to your home to a minimum.
Dave Hederich is offline Find More Posts by Dave Hederich
Old May 15, 2003, 01:09 PM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Li-Ion or Li-Poly?
Hi!
Which cells were involved?
If you do mention a brand, that in no way would imply an unsafe product, it's just good to know the failure mode of specific cells.
Thanks.
meteor is offline Find More Posts by meteor
Old May 15, 2003, 02:11 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Re: Li cells can cause a fire
You better worry about her rolling pin
hoppy
hoppy is offline Find More Posts by hoppy
Old May 15, 2003, 10:26 PM
BING! is offline
Find More Posts by BING!
BING!'s Avatar
usa
Joined Mar 2003
as the world turns.....
used to be that automatic lithium cell chargers experienced fires and cell bloating due to wrong charger settings and user inattention.
with better software, these chargers are now reasonably reliable.
now, there are reports of manual (jumper settings) lithium cell charger experiencing fires and cell bloating due to wrong charger settings and user inattention.
JT
BING! is offline Find More Posts by BING!
Old May 19, 2003, 08:14 AM
BigDave is offline
Eat, sleep and FLY
BigDave's Avatar
Conway, Arkansas
Joined Dec 2002
Re: Li-Ion or Li-Poly?
Originally posted by meteor
Hi!
Thanks.
This particular pack was a Lithium Polymer.
As you stated, this does not imply an unsafe battery, just a precaution as to what CAN happen.
Old May 19, 2003, 09:12 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
It can happen to any type of battery: http://www.rcgroups.com/forums/showt...220#post943220
mw
Mark Wood is online now Find More Posts by Mark Wood
Old May 19, 2003, 10:45 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
HOLY COW!!! I had heard that the packs would "just balloon up", but clearly that is not the case. Thank you for bringing this to our attention. I've been doing all my charging in the garage, but after seeing this I may take additional precautions.
Tres Wright is offline Find More Posts by Tres Wright
Old May 19, 2003, 10:56 AM
BigDave is offline
Eat, sleep and FLY
BigDave's Avatar
Conway, Arkansas
Joined Dec 2002
Exactly my point...
This is exactly what I wanted folks to realize. Hopefully, by admitting my error, others will be aware of what CAN and DID happen.
House still smells like smoke but it could have been MUCH worse.
Be safe, charge them in a container of some kind....
Old May 19, 2003, 05:30 PM
defranci is offline
Find More Posts by defranci
Central Ohio
Joined Feb 2003
Bigdave
Thanks for posting your experience. The picture is a real eye opener. I have been using a pyrex dish in the middle of my garage (concrete) floor and had wondered if that was overkill. Now I Know that it isn't
Don.
defranci is offline Find More Posts by defranci
Old May 19, 2003, 06:00 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Wrapped too tight?
I've observed the application of traditional cell "wrapping" techniques on Li-Poly packs for quite a while...
I've noticed quite a few modellers use the traditional paradigm of wrapping their Li-Poly "packs" with multiple layers of heat-shrink plastic wrap, or tape, or whatever... (Heat-shrink has a pretty high tensile strength, and will resist expansion even more under heat)
Does this not seem like a very bad thing to do to a cell whose designed failure mode is physical expansion?
I'm not sure if there's test data to support it, but if you constrict the ability of a Li-Poly cell to expand, you will probably create the opportunity for a violent rupture.
Thoughts?
Old May 19, 2003, 06:35 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
Does it matter how Lipolys ARE STORED? Reason I ask is that I have 2 - 2 cell packs from Wilds R/C that I havent used in a few months cause I went to 3 cell. Now I have a Tiger Moth and when I hooked up the 2 cell, the radio just glitched. Then I noticed the pack was bloated! The second pack did the same thing but felt fine. I dont remember charging them in some time. I do have a 2 and 3 cell charger so maybe I just had it on 3 and ruined them. Just wierd cause I dont remember even touching them since I bought the new 3 cell charger cause I didnt need them. What else can cause them to bloat or quit working. Just sitting around???
JIMJAM is offline Find More Posts by JIMJAM
Old May 19, 2003, 07:16 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
JJ Hong (ceo of kokam) quote from Jan 4...
"FMA instruction of no full charge storage for more than a month
means if you ate food always full,your stomach will be demaged.This is same reason.normally we charge 50% for the shipping.I think around 4.0 volt will be o.k "
DNA is offline Find More Posts by DNA
Old May 19, 2003, 08:56 PM
Joined Feb 2000
You know, the more you start putting all of these little "gotchas" together, the less user friendly LiPo cells appear to be. Imagine charging your LiPo cells for the last flight of the season, and then having a snowstorm hit. You store your fully charged cells away for the winter, and next spring you pull them out and they are screwed.
You really have to be willing to put up with lots of little things like this. The rewards are pretty good, and many people will be willing to put up with them. But a lot of people are programmed to think of modern products as "plug and play." LiPos aren't there yet. I have a feeling that we are going to be reading lots of messages from casual users who are having various problems with LiPos.
Old May 20, 2003, 12:29 PM
BigDave is offline
Eat, sleep and FLY
BigDave's Avatar
Conway, Arkansas
Joined Dec 2002
Contained somehow
Originally posted by defranci
Bigdave
Don.
Only thing I would add to this is that the pack needs to be "contained" somehow. I would suggest a lid on the dish or something similar.
The pack actually accellerated itself (I can only visualize a rocket-like reaction) and launched off of the charging bench. I did not see the disaster in motion so this is just a guess.
Again, I have no intention of changing battery types. I have several Li packs and really like their performance when it is controlled (well, as 'controlled' as RC planes get anyway).
How many cells can an Astro 210 handle? Martin Irvine Electric Plane Talk 2 Jun 09, 2016 09:08 PM
Surplus 1400 Mah Li-on cells - Can I do a 3-cell pack? mrebman Batteries and Chargers 14 Aug 09, 2004 11:09 AM
how many li-po cells can i use on an original skylarkboard? fly_isse Micro Helis 1 Nov 10, 2003 02:08 PM
Can li-poly packs cause glitching? ronnath Batteries and Chargers 2 Mar 10, 2003 05:33 AM
how many cells can a b50-13xl handle? bpu6999 Electric Ducted Fan Jet Talk 4 Jan 31, 2002 05:11 PM
