Old Sep 13, 2001, 06:01 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Mini-Review
Kevin's F/A-18 construction
I am more than halfway through with the construction of my EJF F/A-18,
http://www.electricjetfactory.com/itemejff18.html
I am getting to the taileron setup part. Does anybody have a picture of how they did it?
I am planning on doing it a bit differently from what the instructions recommend - if can I understand it properly - by using thick piano wire shafts through a brass tube bushing.
Thanks in advance.
Herb is offline Find More Posts by Herb
Old Sep 13, 2001, 10:57 PM
p471701
p471701
Guest
n/a Posts
herb:i had some that haldor sent me that worked well.unfortunately they got wiped out in a hd crash a few months ago. try e mailing him and he could send them to you...........gregg
hlonning@online.no
i used carbon shafts with piano wire inside for reinforcement,and drilled out larger holes in the fuse sides, filled with epoxy and then drilled the correct size for the carbon shafts.this way the epoxy made a nice bushing surface.
Old Sep 14, 2001, 12:26 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Here is a pic of my assembly.
Haldor is offline Find More Posts by Haldor
Old Sep 14, 2001, 03:04 AM
Cees Kraaijeveld is offline
Find More Posts by Cees Kraaijeveld
Cees Kraaijeveld's Avatar
Barendrecht, Netherlands
Joined May 2001
I made the tailerons from 3 mm (1/8") balsa, glued in 3 mm piano wire (epoxy glue of course); bushings were made from brass tubing, inner dia. 3 mm of course. Balsa blocks in the fuselage have been reinforced with 0.8 mm (1/32") plywood on both sides.
Cees Kraaijeveld is offline Find More Posts by Cees Kraaijeveld
Old Sep 14, 2001, 04:29 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Ill send some pics of mine tonight if I can remember . I dont think mine are as nice as some of these guys like Haldor's , I just used what I had on hand. I used a sandwich of 3/32 balsa squares and criss crossed the grains for bushings. I used some wooden dow rods for the piviot shafts. I used 1/8 ply for the control horns and Z bend piano wire for pushrods. Keeping the slop out of the linkage of course seems to be the main point to avoid any flutter. I am trying to keep mine as light as I can as I am using a brushed race speed 480bb and 8 X Cp1300s, so Im not going to be as fast or heavy as these guys with the brushless 10 cell configs.
JasonJ is offline Find More Posts by JasonJ
Old Sep 17, 2001, 05:41 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks for your info, I eventually found the right Dubro hardware for the linkages...wish it was just included in the kit (Robert ). Here is how
I ended up arranging things </A>, it's a simple compact & lightweight setup and seems to work well. I use twin rugged HS-81MG (metal gear) for the tailerons, no slop with brass bushings. I have setup my linkages in such a way that I can do first a mechanical adjustment of the taileron throws.
There is a Dubro hardware 22-piece package (#101 Aileron linkage) that for $5 with some cutting & adjusting has almost all the linkage parts you need for the F/A-18, you only need to buy the collars & brass tube extra,
http://www.dubro.com/cgi-bin/SoftCar...036+1004422790
I also experienced some warping in the horizontal stab after glassing the stab bottom with water based acrylic - even though I applied the acrylic on both sides at the same time. Oh well I am pressing it straight again now - and doubling the thickness of the tailerons.
Old Sep 17, 2001, 06:38 PM
p471701
p471701
Guest
n/a Posts
herb: i tossed the wood for the tailerons, it seemed pretty flimsy. i susbstituted it with some stiffer balsa...........gregg
Old Sep 17, 2001, 08:18 PM
Jim Phelps is offline
Find More Posts by Jim Phelps
Jim Phelps's Avatar
Elizabethtown/Ft. Knox, Kentucky, United States
Joined Jan 2001
I had to toss mine also. I made new ones out of 3/16 balsa and sanded them to a symetrical airfoil. Just started a new one and think I will use the the balsa with the kit and glass it this time. Anyone ever try ailerons on it? I'm thinking of trying it on this one.
Jim Phelps
Jim Phelps is offline Find More Posts by Jim Phelps
Old Sep 18, 2001, 12:12 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Well it's almost done now - except for some details & paint job. I used some MinWax polyclrylic for finish, with lightweight glass cloth on the fuse underside & tailerons.
The kit is very nice and goes together real easy, and the finished product looks quite sharp too . Will first trim it out maybe w/out powertrain and then paint.
Picture of unfinished F/A-18 here </A>
Setup is MF480, Hacker B40-8L, Kontronic Smile 40A BEC esc & 10 pushed CP1300 cells, 380 Watts ca.
Or about 150 Watts per pound, with a (static) thrust to weight ratio of about 0.80.
Old Sep 18, 2001, 12:39 AM
p471701
p471701
Guest
n/a Posts
herb: it is a very nice kit to build.looks great! with the 1300's it should come in light. hand launch?.
i was tempted at 40oz, but went with the launcher........gregg
Old Sep 18, 2001, 10:24 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
...Whether it will be ultimately hand launchable or not will depend on the power & weight, and therefore on static thrust, watts per pound and wingloading. My target is around 150 Watts/pd.
I am not sure yet what the final weight will end up - since I am not done with the paint & fglass yet, and also don't know yet exactly how many CP1300's I'll use...
Anything with a wingloading of under 30 I think I can handlaunch without too many problems , above that it can be risky & the bungee would be the way to go.
I'm almost done with the paint - no panel lines yet -, the finished weight is around 39 oz, maybe when the paint dries completely it will be less ...
[Original, http://www.usscoralsea.net/27/images/vfa27ep.jpg ]
Old Sep 22, 2001, 09:32 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
How did you guys attach the canopy? I put a ply tongue on the front of the hatch, but I think it won't work due to the canopy's placement, the canopy get unglued when I pry the hatch open at the back.
...ok here's how </A> I did it. Hope it stays on long enough.
Old Sep 22, 2001, 09:47 PM
p471701
p471701
Guest
n/a Posts
herb: i had the same problem,i used silicone to attach it to the wood and left a small gap at the rear. when i open it i squeeze it from the sides (at the glue joint) and lift it up and slide it back. hasn't come loose yet.
one bunus from the gap at the rear is; in addition i drilled an air outlet in the wood for some venting of the battery heat............gregg
Old Sep 22, 2001, 11:48 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Wow Herb, Very nice finish. I guess you are planning on a lot of inverted flying.
So the blue bottom won't blend in with the sky.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Sep 23, 2001, 09:41 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
That's a sharp looking Bug (nickname for an F/A-18) Herb!
What did you finally use for your decals?
Kevin Cox is offline Find More Posts by Kevin Cox
Kevin Cox F-18 ready for duty! JasonJ Electric Ducted Fan Jet Talk 8 Oct 12, 2001 03:29 PM
F/A-18 construction / flying exowatt Electric Ducted Fan Jet Talk 14 Oct 01, 2001 06:09 PM
Kevin Cox F/A-18 Conversion to E version? Rob Andrew Electric Ducted Fan Jet Talk 14 Sep 16, 2001 05:45 AM
Cees Kraaijeveld's F/A-18 pics Kevin Cox Electric Ducted Fan Jet Talk 10 Sep 14, 2001 05:39 PM
Covering EJF's F-18 LJH Electric Ducted Fan Jet Talk 8 May 03, 2001 01:12 AM
