One video from a couple of weeks ago
you guys sure having fun there
last sunday we were 9 mini quads many people are catching up with the new mode the kids were a real problem on landing, even thought there were amateur fliers around...
Hey man you are starting to look like this crazy guys from Australia LOL they fly like bat out of hell
6" Minion
Just maidened my new 6" arm Minion...first with GF5x3 and then with FC6x4.5
I must say I like this setup the best of any 3S mini I have flown (QAV250, Armattan CF, DRQ250).....I used the same PIDS as my other 5" minis using a 2300KV motor...only have to tweak the TPA Breakpoint some since it hovers at 38% throttle instead of 50% with the 6x4.5s...will post some video once I get it finalized, but the power is close to the 4S 5" Minion I have with Cobra 2204/1960s and, almost as fast.. Setup: DragonFly 1806/2300 (I really like these motors!) 12A ESCs (see below) 250mw TS5823 32ch 5.8Vtx CC1333 board cam 3s, 1300mah Lipos Flip32 FC ESCs: actually mixed two Afros with two RedFire (Witespyquad) that I had as spares...both are NFET and both use SimonK firmware...cant tell any difference from idle to WOT...good to know |
LOL mixed ESC well in theory it should work maybe it's more work for the FC to keep things nice and smooth.
Yes videos please also post pictures of your build. And thanks for sharing |
Next steps are to solder the ESC's to the afro PDB, set up the LED's, install the battery power cable, then work on the FCB and RX installs. I'm doing a little video as I go along to show how I am doing things. Here's a couple of pics as promised... |
Welwood your build is lokking good very meticulous and clean grate job
hello all!
I am in the process of building my quad and thought it could use some landing gear so I could place the battery under the quad. So I came up with these little guys they only weigh 9 grams seems to be strong too I will be doing some crash testing soon ! What do you guys think of these ? |
6x4.5 props
Pat, as requested...some photos and the latest video...
pretty straightforward...a few things I usually do on my minis are noted in the photos below.. - metal screws - some posts exchanged for aluminum - tilt on vid cam using a nylon spacer and mounting using just a rubber band - 5mm locknuts on motors - diversity Frsky ants mounted in V using tywraps and fuel tubing - cover screw heads on bottom with pieces of Scotch Transparent Duct Tape to prevent scratching my car hood used the same pids for 5x3,6x3,and 6x4.5 (my favorite prop)...love the feel of this mini dodging stuff...a little jello in the mobius even though props were checked for balance (only had to do minor balance work on just one of the FCs).., also tried 3s, 2200mah...a little less nimble, a little slower climb, naturally(example shown at end of video)...but 9.5minutes instead of 5.5 minutes.... next I am going to build a mount for the Gopro and its lens protector and see how it flies even a little heavier
Hey Atx I love the orange lol
For the jello I use foam it works grate I did try gel but not so good You can also use damper "bombings " 4 per arm where the arms are bolted to the bottom plate and I like to have the arm inside the frame so the motors are higher up and allows for taking off on grass, I can post some pictures later. I have thoses DF motors on my hex just waiting on lipos to arrive but so far the seem good. Oh the new kits will come with ss bolts instead of nylon but the standoff will all be nylon, tat combination works grate for me so far after few months and several crashes i only replace props oh and now a motor because i did toasted one Your build is very neat and clean Deno most of this motor were design to run 6" props but I do prefer the 5" minion for batching because I can get it in tighter spots and I like the 6" for speed and efficiency but that's just me Oh here are the pictures with the damper and no damper plate: |
(next time I will prime the pieces before painting...it chips easy as is) AUW? havent weighed it...should be around 500g or so there have been several videos testing these motors with 6x4.5s at continous WOT on 3s with no destruction...but I wouldnt do that myself...only for punch outs...if for no other reason that they draw about 14A doing it and the ESCS are rated only for 12A cont/15A burst (usually 10 sec)....HQ5x4 should be no problem WOT continuous... flying 9 min at hover and just above, as in most of the video, brings motors only to the barely warm state at 85deg F I like them a lot |
New Product | The Minion (another mini H quad) | Patrizio_g | Multirotor Drone Talk | 4 | Dec 10, 2013 09:46 AM |
