#46 |
feed>burp>clean>work>feed>>
Take another look
He's put it back up along with others.......but not the bat! ![]() BTW, he did give plenty of warning in the fox thread in the slope forums, but it's moot anyway, anyone who wants one has now until almost xmas to get free freight. |
#47 |
Speed Junkie
nice good to see ming is keeping the deal going
does anyone think a towerpro 2408-21 motor will work in this glider? (600 grams of thrust)
#48 |
World of Planes has small parts set for ez glider that don't have the clips that break and piss ya off. They have a small round "eyelet" clip for the canopy and a flat clip with a hump that the eyelet snaps over and no breakage. The last two sets iv ordered from them were like that. They want 20.99 which iv seen cheaper but the clips are great. On page 4 search multiplex A good question out there. How do i send pics? Iv got dig camera that plugs into laptop,,,, ty
#49 |
eh?
#50 |
Hooked and loving it!
where? I can't see it on his website..[sheepish] sorry, found it! [/sheepish].
#51 | |
Only one more Honey
This motor is a better replacement for the TP motors http://www.wattsuprc.com.au/product_...sp?pid=EW-M001 I've pushed this motor to 25amps on an 8x6 APC prop. no probs. Or choose the 1200kv http://www.wattsuprc.com.au/product_...sp?pid=EW-M002 Lyndon - who finally received his FOX |
#52 | |
Speed Junkie
the 1200kv motor u suggested puts out 600 grams thrust 13amps 8.3.8 prop i already have the towerpro motor on hand |
#53 | |
Only one more Honey
1. The 2408-21 is a 1400-1700kv motor if you run a 8x4 or 7x6 you will be pulling more than 13amps and they burnout quickly above 13amps. I suggest using an amp meter to test the true amps. 2. The motor will be completely enclosed so cooling is a factor. Just recently a friend and I just burned 3 2408-21 motors, in a cessna. 3. If you motor has one of the gold mounts they are better. see here http://www.towerpro.cn/english/motor/2408.html 4. The ewatts motors can handle much more than there stated amp rating, this is from experience, and testing of the 1800kv the 1500kv and 1200kv. I am suggesting these motors from my own experience. I have used the towerpro motors extensively these are much better http://hobbycity.com/hobbycity/store...idProduct=4899 http://hobbycity.com/hobbycity/store...idProduct=5499 If you have a motor on hand may I suggest to bench test it in the model extensively before maiden. Good Luck |
#54 | |
Good Better Best quest.
similar to this http://www.hobbycity.com/hobbycity/s...idProduct=8650
#55 | |
Only one more Honey
#56 |
how long did it take yours to get delivered? Payment for my two went through on the i think the 1st or 2nd, and he sent it on the 9th... BUT the tracking number says the items destination is in south korea?! Yet all details from Ming are correct.
Any ideas? |
#57 |
Only one more Honey
took mine a little over 2 weeks
#58 |
Speed Junkie
im probably going to go with the wattsuprc 1200kv motor for my fox glider and since theres another motor on there i like i may take that aswell a wattsuprc 1800kv motor for my 34inch flying wing it should be a missile weight of flying wing 280 grams thrust from motr 190 grams pitch speed 122.5kph yikes!!!
| Build Log Windrider Easy Glider EPP Pro w/ V-Tail Mod | Phiber Optik | Foamies (Kits) | 20 | Mar 29, 2007 08:21 AM |
| Windrider Easy Glider | Up&Away | Slope | 23 | Feb 23, 2006 10:51 PM |
| Finally maidened my Windrider Easy Glider | Up&Away | Slope | 0 | Jun 09, 2005 06:35 AM |
| FS: NIB, Mini Fox Glider, Beeline Models | ajeepham | Aircraft - Sailplanes (FS/W) | 9 | Mar 28, 2004 11:20 AM |
| 2M Fox Glider F/S | fw190a | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 05, 2001 02:20 AM |
