Go Back   RC Groups > Aircraft - Electric - Airplanes > High Performance
Old Oct 31, 2009, 06:54 PM   #16
PHP Code:
Yes, if you heat them beyond 170 degrees Fahrenheit (80 degrees Celsiusthe magnets will quickly loose their magnetic properties
Steve whilst I agree using a soldering iron on the armature is not necessarily a good idea. There are several grades of NdBFe magnets some have max operating temps of 180C. The max N rating available in the magnets is lower for the higher temps. Steve Neu recently said that he was using the 180C max operating temp magnets, previously he had been using 150C, probably because the strength he was after was not available in 180C originally.
David H is offline Find More Posts by David H   Reply With Quote
Old Oct 31, 2009, 06:54 PM   #17
One Idiot is plenty...
Dbox's Avatar
Steve,try to heat up the magnets through 3.2mm shaft to even half of the not recommended temps and THEN REPORT.
Yuri.
Dbox is offline Find More Posts by Dbox   Reply With Quote
Old Nov 01, 2009, 09:30 AM   #18
Back in the game
flying evader's Avatar
Originally Posted by CharlieS View Post
What model Kontronik is it, Kira or FUN? I just ordered a FUN 480-42 at Tower and will mate a 5.2 Kontronik GB to it using old loctite 638.
I the pinion on an arc 47 1 turn break loose when I switched to the g3 hyperion cells. I remembered that the shaft was smooth and a bit looser fit to the pinion than most shafts. I sanded the shaft slightly and reset the pinon and flew 24 hours later with no problem.
Charlie
Kira 480 from tower.. couldn't resist the prices..
I took the pinion from an arc motor, which by the way was a pain to get off, even with heat applied... this was applied with 648, which makes me scratch my head since it worked so well on the arc motor...
flying evader is offline Find More Posts by flying evader   Reply With Quote
Old Nov 02, 2009, 06:51 AM   #19
That sickening crunch..
Andy W's Avatar
Any chance the pinion is not the *exact* size?
..a
Andy W is offline Find More Posts by Andy W   Reply With Quote
Old Nov 03, 2009, 05:44 PM   #20
Back in the game
i think it is.. the shaft size is the same as the fun 500.. 3.17mm
Old Nov 05, 2009, 06:58 AM   #21
Andy W's Avatar
Not had to do it often, but I've never had a pinion come loose using loctite sleeve retaining compound (don't have the number) - the green stuff. Up to about 1600W I think. I've never sanded down a shaft, I was told that shouldn't be necessary - you're putting less surface area in contact..
..a
Old Nov 09, 2009, 12:32 AM   #22
"ARF LOVER" in Toronto!
wollins's Avatar
Glad this came up ... I just got my Kontronic GB come in and will be attaching it to an ARC 28-58-1 motor.
While there is absolutely no perceptible side to side "play", I can move/slide the pinion up and down the motor shaft with no apparent friction whatsoever. Is this normal or should it be snug on the shaft?
Colin.
wollins is offline Find More Posts by wollins   Reply With Quote
Old Nov 09, 2009, 03:56 AM   #23
Wrong side of the blue
WimH's Avatar
It's normal. Just clean shaft and pinion with aceton or something similar .
WimH is offline Find More Posts by WimH   Reply With Quote
Old Nov 10, 2009, 11:46 PM   #24
Hi everybody
I have a similar problem. I have a Kontonik Fun 500-48 with a 5.2: gearbox and I think that the pinion has come loose inside ( propstrike! OUCH.....). My big problem at the moment is that I cant get the gearbox off to see what is going on. Close inspection shows what looks like some locktite type goo in the area between the back of the gearbox and the front of the motor.
Any good suggestions on how a girl could get this loose? Or should i just pass it across to the engineers to fix?
Carolyn
Carolynne is offline Find More Posts by Carolynne   Reply With Quote
Old Nov 10, 2009, 11:49 PM   #25
The Kid
Thekid3418's Avatar
Heat and twist if memory serves correctly. Should come off fairly easily
Thekid3418 is offline Find More Posts by Thekid3418   Reply With Quote
Old Nov 11, 2009, 02:27 PM   #26
Back in the game
removing a tightened kontronik gearbox with base hands can be difficult, even with no glue..
I've used pressure pliers with cloth over the GB as to not damage..
Old Nov 11, 2009, 03:47 PM   #27
wollins's Avatar
Ok this is about putting it on as opposed to removing it. Should I just use the blue threadlocker loctite for this purpose?
Colin.
Old Nov 11, 2009, 06:25 PM   #28
Well, I have tried some heat and some covered grips, all to no avail. So, recognising that I am at the limit of my competency, the motor is now going to go on a trip back to the fatherland where this can be fixed properly.
Carolyn
Help w. ideas for Bird of Time H Stabs coming loose. RC Greaves rec.models.rc.soaring 19 Oct 03, 2008 09:29 PM
Discussion pinion coming loose Franz2002_01 Electric Heli Talk 6 Nov 26, 2007 08:31 PM
Pinion keeps coming loose! help sprice50 Power Systems 7 Jun 09, 2004 07:45 PM
help. pinion keeps coming loose Tim F. 3D Flying 5 Apr 03, 2004 08:39 PM
Planes glitching -Tx antenna coming loose inside the radio case jamester Electric Plane Talk 1 Sep 10, 2001 01:38 AM
