#1276 |
Faulty receiver 4G6 ?!...
I have six batteries - one original and 5 of the Storm 3.7 V / 600 mAh, 20C. On each is the same. In the basic version of the engine problem appeared after about 4min40sec, after changing the HP06S Outrunner Brushless Motor and XP-7A ESC, this happens at 3min30sec. It looks as the receiver lost the signal for a split second and then he did not saw the minimum throttle position.
#1277 | |
Amp |
#1278 | |
Maybe just too many test flights with mystery motors. LOL.
#1279 |
Flying in the Concrete Jungle
Anyone Everyone?
How to you fix the tail slider, I just breezed over the whole forum and must have missed it.....where do you put the crazy glue to keep the bearing in place I got like 3mm play |
#1280 |
It is the little slider bearing in the plastic slider housing. The bearing has play within the housing. You have to CA the collar of the bearing into the housing to keep it from moving back and forth.
#1281 | |
How are you going flipping this little guy? Last vids I have seen were really awesome and well we live just a little far apart to have a fly-off! ![]() Having alot of fun with my HH g3....but also enjoying hearing about this heli. ![]() Amp |
#1282 |
U also gotta supe glue the pitchslider arm to the hallow shaft..after you press it together by putting needle nose pliers on the back of the shaft and pressing the plastic slider arm all the way tight with the bearing..
#1283 |
ell after quickly shreding the junk stock dampners, i decided to fnd sumthing better!..i think this should hold upfor a while..i found O-rings in a MIA battery and antenna mounting kit that fit perectly in the head block and firmly over the feathering shaft..smilar to the way the Trex 450 head dampner is set up, then i used very tiny O-rings from the MIA fly bar stabilizer set to use as spacers inbetween the dampner oring and the aluminum bearing spacer. The small o-ring tightens up the dampening and creates a small gap between the dampner and the aluminum spacer to stop it from binding against the head block..
a flew it two flights and now the helicopter stops the weird drifting and sluggy response..everything seems crisp and responsive now..and the head is much much stiffer..so for 5 cents in o-rings it worked out great! heres some pics so you can see the order i stacked everything..sorry there kinda crappy i took em with my Iphone
#1284 |
Power revived when exchanging it for micro deans connectors(dark red plastic) since the power of the batteries had lowered. However, main blades flutter intensely by the pitch of 50% by HP08S/XP7A/T20 because HS is too fast. the same also T18. The flight is exactly crazy but I have come to like it.
Should I change it to the metal head? No problem for you with T20? |
#1285 | |
Good Luck, Don |
#1286 |
Thanks DK, I wound up taking the whole assembly apart at 2am mind you (I need 12 step meetings for heli addiction) and then I saw what you posted, ..popped the slider back into the plastic with a needle nose then Ca'd the metal to plastic, interesting it works better than new now... i like that!!
#1287 | |
#1288 | |
Addicted - seeking help!
#1289 |
#1290 |
Helicopters Annoymous (HA) - Manny is going to deprogram us by showing us youtube videos of hopped up 4g3's & 4g6's in fatal crashes followed by lipo fires. Coffee and cigarettes provided by wowhobbies.
| New Product Walkera 4G6 and CB100 At RcHobbyHelicopter.com | johnIn2SonAZ | Micro Helis | 541 | Nov 13, 2009 10:22 AM |
| Discussion Walkera 4G6 first impression. | ehirobo | Micro Helis | 124 | Nov 07, 2009 05:39 PM |
| Cool a dream come true: new Walkera 4G6 - SD, Pitchtail 4G3 Size | robZulu | Micro Helis | 773 | Oct 28, 2009 03:25 PM |
| Discussion walkera 4g6 | dkintx | Mini Helis | 1 | Sep 01, 2009 08:22 PM |
| Discussion Walkera Lama2 mods. | wufer | Multi Rotor Helis | 4 | Sep 04, 2008 09:57 PM |
