Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Nov 07, 2009, 03:21 AM   #286
deltas are cool
AIR SALLY's Avatar
Barry thats pretty much what we have...some gap is needed so the duct wont rub on the spinner.these "trapped ducts" are a pain ..dont really understand why the front cant be glued.....if i had one i would just bond it with silicon ,so they would'nt rattle around in there....to get the fan out all you have to do is slide the fan back 1/2" and take the tail pipe off and it's out of there.
i put one duct in tonite to test fit it ...seems ok need a few adj to the plugs .i'll get some pics in the morn.
AIR SALLY is offline Find More Posts by AIR SALLY   Reply With Quote
Old Nov 07, 2009, 04:09 AM   #287
Gold Member
monkamarm2000's Avatar
Send a message via Yahoo to monkamarm2000
that's not a bad idea, cause if service is needed, ya just rip it out and re-silicone. i just toy so much i do the jam in thing.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000   Reply With Quote
Old Nov 07, 2009, 01:09 PM   #288
deltas are cool
AIR SALLY's Avatar
Here are some pics just tack up for fitment
  • Name: Tams A-4 002.jpg
Description: after you memove the mounting rails ,cut the notches @1/8 deeper after you memove the mounting rails ,cut the notches @1/8 deeper 46.7 KB · Views: 39
  • Name: Tams A-4 003.jpg
Description: the lighting hole areas need to be sawed out to remove them the lighting hole areas need to be sawed out to remove them 48.3 KB · Views: 39
  • Name: Tams A-4 005.jpg
Description: Grind the area for a bit more clearance ,not too deep into the spar(black area) Grind the area for a bit more clearance ,not too deep into the spar(black area) 39.5 KB · Views: 46
  • Name: Tams A-4 004.jpg
Description: cut into the mounting rails to deepen the notches,this allows the rails to be further apart to better fit the 5" dynamax fan.a 1/8 ply spacer goes under the fan mounts on top of these rails cut into the mounting rails to deepen the notches,this allows the rails to be further apart to better fit the 5" dynamax fan.a 1/8 ply spacer goes under the fan mounts on top of these rails 64.8 KB · Views: 31
  • Name: Tams A-4 001.jpg
Description: front view ..note i have'nt removed the lighting hole area on the aft former,see C/N's pics of the final shape back there to help the tail pipe fit front view ..note i have'nt removed the lighting hole area on the aft former,see C/N's pics of the final shape back there to help the tail pipe fit 45.7 KB · Views: 52
Old Nov 07, 2009, 01:12 PM   #289
deltas are cool
AIR SALLY's Avatar
ok here are the ducts
  • Name: Tams A-4 006.jpg
  • Name: Tams A-4 007.jpg
Description: looking down the throat looking down the throat 50.4 KB · Views: 62
  • Name: Tams A-4 008.jpg
Description: back lit ..still hard to see in there. back lit ..still hard to see in there. 45.1 KB · Views: 86
Old Nov 07, 2009, 02:30 PM   #290
Very nice work.
eazyp2 is offline Find More Posts by eazyp2   Reply With Quote
Old Nov 07, 2009, 03:34 PM   #291
Wow those ducts are sweet!
gunradd is offline Find More Posts by gunradd   Reply With Quote
Old Nov 07, 2009, 07:07 PM   #292
Ron101's Avatar
Very Nice A.S!!
they are looking great!
I had a close call with the A-4 today... I put it up in a 14 mph cross wind..
I will not do that again
coming in I was so crossed up... and getting pushed towards the fence.
I got her down but messed up a main strut... I have to order a new one
that's the last time I push my luck in cross wind... the A-4 has a big stab and really gets pushed sideways... maybe a 5 mph cross wind... but not much more... very lucky!
going to get the strut out and see if I can fix it... if not order a new one from Tam...
Keep up the good work on the ducts!!
keep us posted
Ron
Ron101 is online now Find More Posts by Ron101   Reply With Quote
Old Nov 07, 2009, 07:18 PM   #293
Dream Build Fly Scale
strictlyscale's Avatar
Ron, nice save. I can't imagine flying in a cross wind as stong as that. I have my hands full when its that hard right down the runway.
AS, nice work on the ducts. Makes the A4 a nice project with a modification like that.
strictlyscale is offline Find More Posts by strictlyscale   Reply With Quote
Old Nov 07, 2009, 07:41 PM   #294
20,000 Screaming Watts!
rvincent's Avatar
Wow Ron Don't mess her up now! Glad its ok
Rodger What can I say
rvincent is online now Find More Posts by rvincent   Reply With Quote
Old Nov 07, 2009, 08:28 PM   #295
Ron101's Avatar
Thanks guys.. but I was just plain lucky
I was out of control and did all I could to not hit to hard... pretty lame on my part... but I was just dieing to fly it. I wish I had the video of that...it was crabing so hard it looked insane
Both stuts have a teak in them now and won't work smooth without binding..
Looks like I'm giving some green backs to Tam
but the good news is nothing is broke.. I went over it well and everything seems fine... hope he has some in stock
Got to get her fixed fast!! and slap in the new ducts ..AZ is coming soon
Old Nov 08, 2009, 12:22 AM   #296
deltas are cool
AIR SALLY's Avatar
Bob just picked up his A-4 so now it's his turn to work on her . i have a few issues to fix on the plugs to get them to fit a bit better ...im going to go with 2 layers of glass so they will be up to the task.
Old Nov 08, 2009, 01:22 AM   #297
Ron101's Avatar
Sounds good to me Roger
can't wait to try them out
Old Nov 09, 2009, 03:28 PM   #298
deltas are cool
AIR SALLY's Avatar
bob is your A-4 done yet ...call in sick eh!
Old Nov 09, 2009, 03:31 PM   #299
rvincent's Avatar
Actually working on it right now! Need to get some things from Tam, but it will be done
Old Nov 09, 2009, 03:47 PM   #300
deltas are cool
AIR SALLY's Avatar
Sweet let me know when you run it up ..i need to know if there strong enough.making the changes to the Plugs then i'll get you a set of production partsthen it's rons turn for long ones ....the short ones make swapping the fan a breeze.
Discussion Dyn-E-Max Ducted Fan bladexz2 Electric Ducted Fan Jet Talk 804 Today 06:03 PM
Discussion AMD / JHH HAWK - Dyn-E-Max kevin Electric Ducted Fan Jet Talk 87 Aug 28, 2009 09:46 PM
Video Cook F-4 / twin Dyn-e-max kevin Airplanes - Electric Videos 10 Aug 17, 2009 03:37 PM
Discussion Dyn-E-Max variable exhaust nozzle bladexz2 Electric Ducted Fan Jet Talk 10 Feb 04, 2009 02:39 PM
Discussion Tam Jet F-16 w/ Dyn-e-max Eagle15 Electric Ducted Fan Jet Talk 28 Jan 23, 2009 09:33 AM
