#1 |
polarisdave
Tiny motors
im looking for small motors about the same diameter as a AA battery I want to try to make torps with motors but so far cant find motors small enough
#2 |
Small Motors
You can use small cell phone vibrator motors.
#3 |
Take a look at Conrad.com, i found there my minimotors for my electric torpedo's.
Available in 3,2 V and 1,5 V, diameter 10 mm, ordernumber 233965 (1,5 V) |
#4 |
Tygum Lagoon Terror
GWS IPS motors are 12 mm diameter and 40 mm long, Hobby shop should be able to source them, I use 3 in my 1/72 Schnell boat on 1/2 inch props and Ive never got to full speed (too fast)
![]() Nick |
#5 |
RC sub dude
Try ordering spare tail prop motors for RC helicopters, they are usually small enough.
#6 |
Yea. Tail motors from the mini helicopters are pretty small. I have some here that are 4mm diameter and I have made a prototype electric torpedo with one.
Finding a tiny prop is the next issue! |
#7 |
polarisdave
motors
ok cool thanks for the ideas guys lol like most people i have like 6 old cell phones jsut laying around will try that and MFR i will look into that website as well i love your torp vids man those things rock. and i will go to my hobby store and see about tail motors. will keep you guys informed on my build if you want thanks again dave from saskatoon
#8 |
You can also pirate the motors from old servos. Some of them are pretty small.
#9 |
Man from Atlantis
#10 |
Nick
Where did you get the 1/2" props? |
#11 |
Tygum Lagoon Terror
Hi Yehya
They were from Classic Warships or something like that, they were scale replacements for the Revell Schnell Boat in cast white metal, I had to drill out the hub and lock-tite them to my shafts. Tiny silicon fuel tube for couplers. Nick |
#12 |
You can use small square KS tubing for a hub and snip blades from shim brass. Solder the blades to the brass hub on an angle. They are so small that bending the blades into a pitch is not necessary. I have also used square plastic tube and very thin ABS sheet to make small props. The work fine.
#13 |
You could also resin cast small props from different sub models to use. That way, when you do lose a torpedo or two, it's not as big of a deal.
Britt |
#14 |
the GWS IPS motors are available in different winds. There are ducted fan versions for speed, or geared versions replacements. Cost around $10 .
Frank |
| Discussion Tiny motors using 14mm Stators from Colorado/Travan Tape Drives | evdo | Electric Motor Design and Construction | 21 | May 04, 2006 12:36 PM |
| Wanted GWS EDP50 XC motors and tiny controllers | eatapogy | Aircraft - Electric - Power Systems (FS/W) | 1 | Jan 04, 2006 09:28 PM |
| Tiny motors | jfcgnv | Indoor and Micro Models | 5 | Dec 05, 2005 07:15 PM |
| 4 tiny motors for RFFS-100??? | phuffstatler | Indoor and Micro Models | 1 | Apr 24, 2003 04:39 PM |
| Know anything about tiny motors? Help! | Monouk | Indoor and Micro Models | 1 | Mar 07, 2003 09:08 PM |
