Go Back   RC Groups > Aircraft - General > Radios
Old Nov 04, 2009, 10:51 PM   #1
fly smooth and fly longer
skorski's Avatar
DX6 mixing 3 on 1
I'm trying to figure out how to combine the dual rates for ail/ele/rud on one switch. Is it possible?
Right now ail/ele are on one switch & rudder on it's own. I would rather have them all activated/deactivated at the same time.
The setup is DX6 Tx & ar6000 Rx, with 4 servos.
Mike.
skorski is offline Find More Posts by skorski   Reply With Quote
Old Nov 05, 2009, 06:34 AM   #2
Air, Ground & Water
Not sure about the DX6 if the programming is different then DX6i, but DX6i programming menu contains a section or feature D/R COMBI which combines all 3 AIL/ELE/RUD on anyof the D/R switches.
freechip is offline Find More Posts by freechip   Reply With Quote
Old Nov 05, 2009, 03:10 PM   #3
skorski's Avatar
Freechip,
Not that I can find.....I'm thinking i'll just give full throw to the rudder with a healthy dose of expo and not worry over it.
I hate being on a budget sometimes!
Mike.
Old Nov 05, 2009, 06:32 PM   #4
Air, Ground & Water
Dual rates & Expo are usualy user prefference. Some will use D/R as a option for when they let someone elso fly their plane or heli.
Some will just use Expo, some will use both & other will use none.
Just experiment with different settings and I am sure you will find a setting that works for YOU and you're RC.
Old Nov 06, 2009, 02:55 PM   #5
skorski's Avatar
I can't seem to figure out how to get expo on rudder! I thought it existed but can't find it in the manual.
Oh well.....I'll just have to be gentle!
Mike.
Old Nov 06, 2009, 03:23 PM   #6
ebill3's Avatar
Mike.
The DX6 does not offer rudder expo.
Dimension Engineering (http://www.dimensionengineering.com/ExpoDuo.htm) did market a device to add expo, but they have discontinued it. Might post a want on the for sale wanted pages - someone might have one laying around.
Bill
ebill3 is online now Find More Posts by ebill3   Reply With Quote
Old Nov 07, 2009, 01:14 PM   #7
skorski's Avatar
Thanks bill,
I'm going to give it a try without, I'm pretty good with the rudder but I'll keep that mod in mind.
(Along with the need to upgrade my TX).
Mike.
Discussion DX6/6i Elevon Mixing different? jpwkeeper Beginner Training Area (Aircraft-Electric) 1 Oct 12, 2009 07:16 PM
Discussion Can I use 2 servo on FC 1.3?? pbcknot Aerial Photography 1 Oct 02, 2009 11:48 AM
Discussion AR6400 on 3Channel Mixing How To? Fidy$Trainer Indoor and Micro Models 1 Sep 18, 2009 11:36 PM
Question Mixing elevons and a canard servo on a DX6? Spackles94 Radios 2 Apr 27, 2008 01:10 AM
Discussion Mixing Throttle to Elevator on the DX6? lovespicyfood Radios 2 Jan 07, 2007 01:48 AM
