#1546 |
Back in the land of sand
#1547 |
#1548 |
Hodge Hound #7
Location: west of the Sandias, east of the Rockies, and far away from my Hodgehound buddies
I agree straight wing. You dont need the dihedral. THE SSX is such an awesome flyer.
#1549 | |
I beat Pud 3-4 days a week
#1550 | |
Right beside him. He grew up right down the street from me in Carrollton. I even let him fly all of my helis
#1551 |
I did it too, but Alcohol was involved! Look at Youtube for username Footballbat74. I have some videos of Joey at night..
#1552 |
This is the best pic I have on my computer. Unfortunately, I can't go out and take a pic because I am out of the country until mid January
#1553 |
Good enough. Thanks.
I like that all 4 of your servos are under the wing. he aileron servos on the one I have are just screwed into sheeting up top. Jimmy |
#1554 |
TOO MUCH FUN!!
SSX Fus.
I read about someone making a fus. for the SSX. Anyone have any picks or links to post's.
#1555 |
My buddy put the SSx down on its back 2 times times doing looow. slooow, inverted wing tip drags today..Both times just flipped it upright afterwards and flew off..
I cant fly like that and am still considering the dihedral wing..Ive got to decide because ive got to cut something one way or another..I can fly the straight wing and it flies great but I get all dyslexic when inverted and lose orientation too often and feel that I could use a little bit more self stabilization. Stabilization isnt really the right word as the straight wing doesnt have any bad habits that I have seen at all and is very stable Maybe the trainer configuration will give me a little more time to think or correct..I dont know I can always build another wing for it. How much difference is there in the flight characteristics of the 2 different builds. Im assuming the X Trainer responds a lot better than the styrofoam wing GWS Slow stick that Im flying now. (for the last week) It is very relaxing but I definitly want snappier performance than it has. I put over an hour airtime on the GWS today.Perfect 68f and 0-5 wind..cnt beat the conditions today. Thanks, Jimmy |
#1556 |
Is there a pic anywhere showing the trailing edge crutch installed?
Does it center the trailing edge of the ribs and match the shape of the rib trailing tip? Thanks Last edited by jamesppp; Nov 09, 2009 at 07:38 AM. |
#1557 |
Don't be scared, fly it!
Jimmy, are you gonna swing by the store tomorrow?
Robert |
#1558 |
#1559 |
I didnt think to try the search function for info on the trailing edge crutch.
Since the trailing edge of the used SSX I bought a couple of weeks ago isnt built like this new kit, I didnt know exactly what kind of bevel it needed I didnt bevel the first one nearly enough and cut the tabs out of the notches to test fit it....I tried to clamp it to the table edge with a metal ruler across the front edge but I dont have it sanded enough yet and it is already in 3 pieces... Hopefully Ill be able to piece it in enough to hold the trailing edge straight enough so that with the upper and lower sheeting strips applied it will be true Unfortunately the nearest hobby shop that has a decent wood selection is 65 miles away Last edited by jamesppp; Nov 10, 2009 at 11:58 AM. |
#1560 |
Im wondering what prop to use with this setup
My GWS SS has a TP 2409-10 motor with an 11x4.3 on it. The Scorpion powered SSX has an 10x8 prop on it I ordered the BP 2212-13, 1000kv motor/mount combo from James with my kit. All of these are/will be flown with 3S power from 1350-2200mah. Im using a Castle P-25ESC on the SSX. With 4 digital servos I may use a Dimension Sport BEC also but will try not to. I might just use 2 hs-55 on the ailerons and 2 HS 65mg on the tail surfaces. The internal BEC on the ESC should be fine with 4 analog servos ...maybe Thanks, Jimmy |
| Discussion Slow Stick X build - a second one | Bayward | Electric Plane Talk | 31 | Feb 06, 2008 08:50 AM |
| Video SLOW-STICK X Build Part 2 Tail Feathers | jkarpy | Airplanes - Electric Videos | 0 | Mar 05, 2007 05:15 PM |
| Video SLOW-STICK X Build Part 1 | jkarpy | Airplanes - Electric Videos | 0 | Feb 18, 2007 05:24 PM |
