#8776 |
I would like to try the new firmware
My MK is not interested in new firmware. I am stuck with what it came with, 0.70d. I use MK tools 1.53 and happily update settings with it. When I try to use the terminal however it messes up and gives me gibberish. If I flip the MK power off and on I get a few legible lines of start up text, then it goes back to gibberish. Anyone know what this is? The gibberish constantly updates like something is being read without line feeds.
#8777 |
Tinkering again!
Yes, definitely redundancy. I once witnessed the LED on the AR7000's satellite RX turn off for a second or 2....this means loss of signal. Thankfully the main unit itself (AR7000) was there as backup.
#8778 |
Aerial video and photography
agreed i use mine for the redundancy and also the MK did some strange things when only one sat was used. One other thing is that I trigger two camera's with my servo parallel to one channel output so that is nice.
#8779 | |
I know it sounds strange and silly but did you install the pressure sensor the right way in the board? it does have a polarity and I know you have it disabled but who know's what it may do if installed backward....
No beeping usually means no shorting... and no seizing of servo's to cause overload of the onboard bec or your own beck.... I am sure you have tried other batteries. I would tie it down tho the garage floor and put normal flight throttel on it. Then watch the ESC lights, main board light and make sure none of them turn red.... ever... Then check how warm your battery is, also how warm the motors are and the voltage regulator..... let us know how that goes. oh and also see if it throttels up on you when tied down and under controlled elevation conditions. A picture of your setup may reveal something too. Quote:
#8780 | |
Very nice design. Sounds a bit heavy for MK, but could be good for 500/600 heli. I'm a bit afraid that it may be ... not so cheap. |
#8781 |
FPV Flyer
#8782 | |
Updating the SW does not work? Frederic |
#8783 | |
FPV Flyer
#8784 |
Don't disturb the pilot
AZ Choppercam,
Very nice, my compliments, I've sent you an email inquiring about the gimbal. Cheers, Sander. |
#8785 |
is anyone flying x with a 1.3 board and if so do you have the tilt working? I can't seem to get it on any of the pads (J-3 4 5 or 7)
#8786 |
#8787 | |
When it updated it suddenly stopped sending garbage and after updating it started again, just as you described. In the past the update process would just not work. I used another laptop this time, something must have been different. |
#8788 |
Hi lads, looking for some more advice if possible.
The last time i used it my mikrokopter worked fine, left it idle for a week and went to fly it today. Turned it on and it tested the SC's as usual. Went to start the motors then and they all worked except one whose SC was flashing. I then turned it off and on again and it no longer tests any of the motors? just gives 2 beeps from the FC then nothing......... I have plugged into MK tool and it says I2C error and none of the motors registered. Any ideas appreciated?? |
#8789 |
thanks frederick, I did not know that they moved it... SV2... I will have to look for it... thanks!
#8790 | |
Frederic |
