Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Nov 01, 2009, 10:19 PM   #4366
M.Huerta's Avatar
ok thanks..i remember seeing the pics from ohio e jets a couple months ago and I never got around to asking
M.Huerta is offline Find More Posts by M.Huerta   Reply With Quote
Old Nov 01, 2009, 10:32 PM   #4367
deltas are cool
AIR SALLY's Avatar
the full scale Hawks have bumps on the wing to cover the wheels ...i have a belly pan with bumps but i doubt that your gear are in the same place that mine are.you could try shiming the gear a bit to tilt the gear into the well a bit more.
AIR SALLY is offline Find More Posts by AIR SALLY   Reply With Quote
Old Nov 01, 2009, 11:45 PM   #4368
gravity,its the law
viol8r's Avatar
I thought about that, but then when deployed they'd have the same amount of inward angle
viol8r is offline Find More Posts by viol8r   Reply With Quote
Old Nov 02, 2009, 08:46 AM   #4369
Birger de la Peņa
bdelapen's Avatar
Originally Posted by viol8r View Post
Has anyone built with MAP retracts and Sapac struts? I can't get my mains to retract fully into the wing , the strut hits the air cylinder and won't folly retract. I did try filing a little off the strut and it helped but to get it get the wheel all the way out of the airstream I'd have to file too much off and weaken the strut. Do they fully retract with the Sapac retracts?
Yes, The Sapac struts and Sapac retracts work together without interference and retract completely without adjustment when mounted into the supplied hard points. If your struts are hitting the air cylinder when retracted I would be concerned that you aren't achieving a positive lock and that the only thing holding them up is air pressure; this could pull the retracts out in high G maneuvers. Of course, this is not that big a deal when retracted vs. when deployed but still.
- Birger
bdelapen is offline Find More Posts by bdelapen   Reply With Quote
Old Nov 02, 2009, 06:40 PM   #4370
gravity,its the law
viol8r's Avatar
Thanks, looks like I'm going shopping again.Whats the point of retracts if they hang out and still cause drag.
Old Nov 04, 2009, 04:47 AM   #4371
j0e
j0e's Avatar
Hi guys, i a thinking of buying this T 45 for a winter project. After reading all 292 pages i am comvinced that this model is so fun and quality!
As far as the setup is concerned, in case i will not find the kit with the motor and fan i am thinking of a HET 2W20 on 4s or 2W23on 5s for a start. Do you think these setups will hit 100mph?
Is there any other setup out there that can hit 120-125mph in 4s?
Another query i have is the weight of it on 4s. I am planning on some dsr retracts so i wonder if they will do the task cause i dont like messing with the air ones.
regards.
j0e is offline Find More Posts by j0e   Reply With Quote
Old Nov 04, 2009, 07:47 AM   #4372
Jetnfast's Avatar
The V2.1 with the motor and fan has yet to be listed on SAPAC's website, but you can call them (Janette) and they will give you a "kit" price with motor and fan. I think I paid $249.00 for the V2.1 w/motor and fan. You cant go wrong with this jet, the build has been very enjoyable so far although I dont think I will have her in the air before winter gets here, I might have to wait till spring/summer!
Cheers,
Jetnfast
Jetnfast is offline Find More Posts by Jetnfast   Reply With Quote
Old Nov 04, 2009, 08:16 AM   #4373
j0e
j0e's Avatar
Cheers,
Jetnfast
w/motor and fan means without motor and fan or with motor and fan?
do you have a link where i can buy this jet from Japan? In rc-warbirds they dot have it in stock and i think is sold without the motor. I leave in Greece. Sapac America dont send here and i prefer to deal with Japan or China shops.
thanks for the response.
Old Nov 04, 2009, 11:37 AM   #4374
Hi guys, I need some servo advice: I purchaced a T-45 V2.1, and their retracts from SAPAC. Since I'm a fan of Hitec servos, I was planning to use the following servos: HS-65 HB for the Ailerons, Flaps, Rudder, and Retact Valve. For additional strength, HS-65 MG for the Steering and Elevators. I know the HS-65HB may be over-kill for the Retract Valve, so I may go for a less expensive servo for this application.
What do you guys think?
Regards, Bonanza
Bonanza is offline Find More Posts by Bonanza   Reply With Quote
Old Nov 04, 2009, 12:29 PM   #4375
Vault-Tech Approved
Racebelly's Avatar
Joe,
w/fan & motor means "with". w/o means "without".
Racebelly is offline Find More Posts by Racebelly   Reply With Quote
Old Nov 05, 2009, 07:49 AM   #4376
j0e
j0e's Avatar
ok i am ready to order but i dont know if to buy the stock motor. what is the top speed it can reach with the stock motor? 100mph in level flight with 4s and retracts?
Old Nov 05, 2009, 11:20 AM   #4377
deltas are cool
AIR SALLY's Avatar
at least 100 mph
Old Nov 05, 2009, 11:29 AM   #4378
j0e
j0e's Avatar
Originally Posted by AIR SALLY View Post
at least 100 mph
wow that was exactly what i wanted to hear!
It seams that the navy painted T-45 is sold out everywhere, but i found the red arrow version named as T-45 v.2 too. Are the v2 red arrow and navy colors the same model?
in espritmodel shop all have the same name T-45 GosHawk
http://www.espritmodel.com/index.asp...S&Category=762
Old Nov 05, 2009, 11:35 AM   #4379
Birger de la Peņa
bdelapen's Avatar
The red arrows and the blue arrows are basically the exact same airplane except for 2 things, the color scheme and the red/blue arrows have ventral fins where the T-45 Navy has an arresting hook.
Regards,
- Birger
Old Nov 05, 2009, 11:35 AM   #4380
thedeuce's Avatar
Joe,
The esprit model is the one made by eflight.
Eflight has it on their website.
http://www.e-fliterc.com/Products/De...ProdID=EFL8025
thedeuce is offline Find More Posts by thedeuce   Reply With Quote
EAM T-45 Goshawk Nearing Completion, Weight Concern NCC-1701 Electric Ducted Fan Jet Talk 7 Oct 22, 2004 05:24 PM
T-45 goshawk EAM cwoodyfly2001 Electric Ducted Fan Jet Talk 0 Sep 11, 2004 08:11 PM
FS: EAM T-45 Goshawk Kit EDF jet_jer Aircraft - Electric - Airplanes (FS/W) 2 Nov 18, 2003 06:27 PM
Anyone flying an EAM T-45 Goshawk geoff.sim Electric Ducted Fan Jet Talk 11 Nov 02, 2003 07:04 PM
T-45 Goshawk On the Deck !!!! EAMRC Electric Ducted Fan Jet Talk 2 Jul 20, 2001 01:37 AM
