Go Back   RC Groups > Aircraft - Exotic and Special Interest > Ornithopters
Old Nov 05, 2009, 07:19 AM   #1
Suggested mods for the Fenice for better control
Well ..I like the slow flying characteristics of some other ornis ... like the Silverlit I-bird or Airhogs V-Wing avenger ..and Ireally wonder how Ican make the Fenice fly at slower speeds ... it may make it more controllable ...
I'm looking for mods that are not pricey and doesn't include using a tail servo for the tail .. because that will require a receiver , speed controller ,and a servo ... What about changing wing geometry ... .. playing with CG ..maybe change gearing ...I really appreciate any ideas
thanks a lot
Khaled
khaled_abobakr is online now Find More Posts by khaled_abobakr   Reply With Quote
Old Nov 06, 2009, 03:28 PM   #2
Site Sponsor
NChronister's Avatar
You might slow it down a bit, by the following modifications:
1. Extend the tail using a thin depron.
2. Shift the CG aft, eg by moving the battery.
3. Cut the wing along the midline and splice some material in to widen it slightly, to provide slack.
However, the two-winged ornithopters will inherently tend to fly much faster than the 4-winged counterparts.
NChronister is offline Find More Posts by NChronister   Reply With Quote
Old Nov 06, 2009, 06:08 PM   #3
Could you please elaborate more on mod #3
Thanks a lot Nathan
Khaled
Old Nov 06, 2009, 08:41 PM   #4
Live to ride... and fly!
Tres Wright's Avatar
You could also try removing the body to save weight. Lighter wing loading will result in slower possible flight speed. Good luck!
Tres Wright is offline Find More Posts by Tres Wright   Reply With Quote
Old Nov 09, 2009, 08:10 AM   #5
Site Sponsor
Yes, Tres's modification is probably the most important of all! As for my #3 the idea is just to put some more slack in the wings so they can deflect a little more under load, and take on more camber. I've found this allows a slower flight -- but also requires a more rearward location of the center of gravity, hence #2. Simply cut the wing down the middle, then tape the two halves back together, adding a small (1/4 inch or so - experiment) gap between the wing halves. The gap should be greatest at the trailing edge and taper to zero if you extend the lines to the leading edge of the wing.
Old Nov 11, 2009, 06:52 AM   #6
4 winged Fenice with wing deflection control ??!!
Well
Here are some suggested mods for the Fenice ... since I'm stuck with it
1- Convert the Fenice to 4 winged orni using the spare wing set
2- Using the tail Actuator to deflect the wings for steering instead of the tail like the I-vamp
Any tips or hints on the how to .. are greatly appreciated
Thanks a lot
Khaled
Old Nov 15, 2009, 07:04 AM   #7
Hi Nathan
Please see the attached photo .. is this what you want me to do ??
Khaled
  • Name: fenice wing widened.jpg
Discussion Does slow spinning propeller slow down airplane and why? dziedrius Modeling Science 21 Oct 16, 2009 08:11 PM
For Sale RC Firebirds "I'm Fenice" ornithopter sale $35 bugstugler Aircraft - Electric - Micro & Indoor Airplanes 0 Sep 07, 2009 03:51 PM
Discussion New I,m Fenice bird now available harrisdouma Ornithopters 85 Dec 22, 2008 08:25 AM
For Sale I'm fenice. Very cheap :) tttttx Aircraft - Electric - Airplanes (FS/W) 37 Jul 27, 2008 08:46 PM
Alert I'm Fenice For Sale Flyboy70 Ornithopters 0 May 05, 2008 11:06 AM
