#1 |
Why default discharge value 3V per cell?
Hey guys,
Just a short questions from someone who wants to store a dozen or so lipos for the upcoming winter season. This will be my first time discharging lipos for storage, so I was wondering: My Mystery B6 discharging function shows 9V for 3S, 6V for 2S and 3V for 1S - how the hell can this be good or am I missing something? Isn't this waaaay to much for a lipo? And yes, I am using the LiPo function (since it supports other battery types as well). I just really wanted to ask before destroying most of my lipo collection Thanks for your input!
#2 |
Yes that's way to low and will probably kill them. I store mine at 3.85V/cell and that seems to work.
Regards Terry |
#3 |
Cheers man, 3.85V sounds about right. Why the hell would they include that as a default program? The lipo program won't let me change any values for discharging, so I should probably just keep them in the cycle, eh?
#4 |
A man with too many helicopter
Most all the high-end chargers and some of the low cost chargers have a storage charge or discharge mode. Sometimes you have to read the manual to know for sure.
#5 |
Just interupt the charge when the voltage is about 3.9V/cell they will then settle back to around 3.85V/cell
Terry |
#6 |
It sounds like there's some confusion between a storage charge (~50%) and a discharge. The latter is usually not recommended for LiPos. As for why it offers that for LiPos, maybe that's why the charger is called a "Mystery"
#7 |
you cant go wrong if you store them at the nominal voltage.
#8 |
Right, gotcha. Thanks for the input guys, much appreciated!
#9 |
Southern Pride
The 3 V per cell for discharge capacity checks was from many years ago when most LiPolys were 3 to 6C rated and also most were under 1000 mAh . The combination of a low rate discharge such as most charger are capable of,newer 20c and greater cells and 3 V per cell will dmage them.
Years ago I used one of my Triton chargers to place LiPolys in storage by using the Ni setting. For a 3S set to Ni discharge and 11.4 volts. When the discharge is done the voltage will rise some but anything between 3.7 and 4.0 is fine. Charles |
| Discussion Lipo at 3.3v per cell won't charge | jkarnacki | Batteries and Chargers | 3 | Jan 06, 2008 08:59 AM |
| Question Li-Poly--why charge to 4.25V per cell? | lectraplayer | Batteries and Chargers | 18 | Jun 13, 2007 12:33 PM |
| Discussion Polyquest xp packs dropping below 3V per cell | Sul1 | Batteries and Chargers | 24 | Mar 03, 2006 10:40 AM |
| Opto 70 & lipo 3v/cell discharge monitoring | No Step | Batteries and Chargers | 11 | Nov 06, 2004 12:49 AM |
| Question Min. Discharge Per cell? | Tommy632 | Batteries and Chargers | 6 | Mar 24, 2003 09:25 PM |
