Go Back   RC Groups > Aircraft - Electric - General > Electric Motor Design and Construction
Old Oct 28, 2009, 10:59 PM   #1
One flight ahead of the rain.
Fishjunky's Avatar
Anyone rewound a Turnigy 35-30 1700Kv?
I'm curious to see if anyone has rewound one of these?
I'm trying to figure out if I have to pull the stator off in order to rewind it.
Fishjunky is offline Find More Posts by Fishjunky   Reply With Quote
Old Oct 29, 2009, 12:43 AM   #2
Former North Coast Flyer
IBCrazy's Avatar
You don't need to pull the stator, but it will help you get a better winding. Pull the bearings out of the motor and put a soldering iron in the bearing tube. this will warm up the epoxy holding the stator in place (if there even is any). Once it gets warm, drive 3mm screws through the backplate into the stator windings. You can put a piece of metal in between the screw and the stator to protect the stator insulation if you want. This will drive the stator out so you have room to work. You don't need to take the whole thing off, but just move it out an inch is plenty.
-Alex
IBCrazy is offline Find More Posts by IBCrazy   Reply With Quote
Old Oct 29, 2009, 01:36 AM   #3
RCalldayLong
yangster's Avatar
good Luck! I couldn't get the stator off and when I did I ended up destroying the motor in the process. If you get it off, let me know how easy it was.
yangster is offline Find More Posts by yangster   Reply With Quote
Old Oct 29, 2009, 02:53 AM   #4
manuel v's Avatar
Fishjunky.
Check post 10,11 and 12.
http://www.rcgroups.com/forums/showthread.php?t=1079423
Manuel V.
manuel v is offline Find More Posts by manuel v   Reply With Quote
Old Oct 30, 2009, 12:56 AM   #5
Fishjunky's Avatar
Thanks for the help all! I'll give it a shot and see how it goes. I have two possible victims, one's mine.
Old Nov 04, 2009, 10:36 AM   #6
Fishjunky's Avatar
I got the stator off but it wasn't easy. I inflicted some minor damage to the aluminum housing, that I'm hoping won't affect it too much.
I used a 60 W soldering iron to heat up the metal after removing the bearings. I then used a battery terminal puller with two nuts in the bearing hole to push against. This left some marks down inside where the ring is that the bearing rests against.
I could not get the windings off in such a manner that I could count how many turns, also some of the ceramic coating was chipped off in the process. There was so much epoxy in the windings that it would not come undone.
  • Name: batteryterminalpuller.jpg
Description: Battery terminal remover Battery terminal remover 11.9 KB · Views: 17
Old Nov 05, 2009, 04:24 PM   #7
D---==-O
Truglodite's Avatar
I have one of these motors too, and feel it's not airworthy with the stock windings (it is sitting in my spares box collecting dust). I haven't seen any decent rewinding results from these motors yet, and it seems like a rewind would have to be spectacular for all the labor involved. Please let us know how it turns out when your done.
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite   Reply With Quote
Old Nov 05, 2009, 05:09 PM   #8
Usual suspect.
Originally Posted by Truglodite View Post
I have one of these motors too, and feel it's not airworthy with the stock windings....
Same for their stock bearings.
dashunde is offline Find More Posts by dashunde   Reply With Quote
Old Nov 05, 2009, 10:16 PM   #9
Fishjunky's Avatar
I don't really know much about how to do a proper bench test. I rewound one of the motors today with 8T of 24G wire. Lots of space left but it's the biggest wire I had on hand.
Here is the Eagle Tree data with no load, not sure how to interpret it though.
edit Sorry I didn't have the RPM logger calibrated correctly for this motor. The log below now reflects a 14 pole motor with a direct drive 1:1 ratio. Am I correct in using the number of magnet poles? Or should I be using the 12 stator pole number?
My next one will be with 22 or 20 gauge wire.
  • Name: 3530_Rewind1.jpg
Old Nov 07, 2009, 03:12 PM   #10
D---==-O
Truglodite's Avatar
Ideally you want to hold WOT for a little longer, so the WOT part of the graph is somewhat flat; what you have is more of a peak than a plateau. That has more to do with bench testing method than interpreting the graph though. Anyhow, as long as you capture at least one data point at WOT, your results will be good enough to discuss... it's just that numerous data points from a flat WOT line helps filter out the "spikes" in the data. If your single data point happens to be a spike, your predictions will stray from reality.
How to interpret the chart?
To get WOT data from your graph, first you need to include Amps on the right Y-axis (also Temp if you are testing props and have the sensor). Then under your chart settings, set the x-axis limits so only the WOT portion of the test is shown. Now the graph should look more or less like 3 flat lines. If a large spike appears on any of those lines, limit the x-axis further until the spike is out of range (no longer visible). After you do this, the averages shown in the legend (underneath the graph) will accurately represent WOT performance (at no-load in this case).
Yes, you are correct. Use magnetic poles for calibrating RPM, not stator poles.
Cheers,
Kev
Old Nov 09, 2009, 10:56 AM   #11
Fishjunky's Avatar
Second wind 9T 24G GB newbie wire
Ok, Let's take a look at this capture from my second motor. I put 9T of 24G wire on this one.
Kev, Thanks for the advice. Attached is a graph like what you described above. I don't have the temperature probe.
I'm seeing anywhere from 1584Kv to 1614Kv depending on which numbers I grab. Is this correct? Efficiency is the next thing I'd like to figure out.
Thanks for all the help and suggestions so far.
  • Name: 3530_Rewind2.jpg
Old Nov 09, 2009, 04:49 PM   #12
Fishjunky's Avatar
Here is another capture with an APC 10x5 prop on the latest re-wind.
After this WOT capture, I could smell that the motor was heating up. It's about 58 deg. F out right now. It did not burn anything up but it was hot.
How much will this change during actual flight versus static testing on the ground?
  • Name: 3530_Rewind2_APC10x5.jpg
Old Nov 09, 2009, 06:05 PM   #13
manuel v's Avatar
Maybe your problem is a thin wire.
one stator 28x9mm is good for 14t, 22awg.
and 7-8 turn 20awg.
Manuel V.
Old Nov 09, 2009, 06:46 PM   #14
Fishjunky's Avatar
I'm going to check out a local place tomorrow to see if they have any good wire options. I have some 22G wire from Radio Shack but I don't have a lot of confidence in it. I don't think I could get 14t of it on this stator.
Old Nov 10, 2009, 07:40 AM   #15
Replikit Designer
vintage1's Avatar
the 1100KV version of this is only safe on a 10x7 on 3s.: If you have both a higher KV and thinner wire, you are over the limits.
It OUGHT to be trying to draw 30A plus. If its not, its all down to poor efficiency and a LOT of extra heat.
You should be on I would say an 8x6 or 9x5.
vintage1 is offline Find More Posts by vintage1   Reply With Quote
For Sale MicroDAN 2003 F3P-29T 1700Kv + Turnigy Plush 6A msmith Aircraft - Electric - Power Systems (FS/W) 2 Oct 17, 2009 09:15 PM
Sold TURNIGY 35-30A 1700Kv awayne Aircraft - Electric - Power Systems (FS/W) 3 Jul 12, 2009 06:26 PM
Found Turnigy 35-30A 1700kv Brushless Outrunner Flying Beagle Aircraft - Electric - Power Systems (FS/W) 0 May 23, 2009 06:38 PM
Sold Turnigy AerodriveXp SK Series 35-30 1100Kv / 345w bwoollia Aircraft - Electric - Power Systems (FS/W) 1 Apr 06, 2009 07:10 AM
For Sale TURNIGY AerodriveXp 1700kv/350 Watt Brushless Outrunner (Eq AXi 2808) $30 Shipped! kctrading Aircraft - Electric - Power Systems (FS/W) 2 Sep 25, 2008 11:02 PM
