Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
This thread is privately moderated by adreher, who may elect to delete unwanted replies.
Old Nov 02, 2009, 09:45 PM   #526
hey guys great thread does any one know if Krylon indoor outdoor gloss will work on epp i sprayed a test and i think it is warping the foam
newfoambe is offline Find More Posts by newfoambe   Reply With Quote
Old Nov 12, 2009, 04:10 AM   #527
DreamArcher's Avatar
Finally getting a little love from my airbrush.
  • Name: Guppy QB (Quick Build) 01.jpg
Description: Guppy QB (Quick Build) Guppy QB (Quick Build) 90.3 KB · Views: 64
DreamArcher is offline Find More Posts by DreamArcher   Reply With Quote
Old Nov 12, 2009, 01:40 PM   #528
For masking, is it just me or is masking tape the worst thing to use for masking? For me if I do a dark color the tape just soaks up the paint and pulls it under and it looks like crap.
I've been using scrap depron and cut lines, angles, curves, etc and just lay it down, spray and lift it off. The plane above is just straight lines but I did some slightly more complex designs and more colors with that technique.
I'm enjoying 3-color designs. 2 subtle colors and a bright high-light. I've done 3 planes like this and at least the color combination have looked nice.
Old Nov 12, 2009, 06:01 PM   #529
Prop Buster Extraordinaire
philba's Avatar
Nice job on the paint, DA.
The standard trick for masking tape is to spay a light coat of clear before you use color. The clear wicks up and shuts out the color.
I've found that using a simple template is great with an airbrush. Angling the brush so it spays away from the part you don't want to paint helps a lot.
philba is online now Find More Posts by philba   Reply With Quote
Old Nov 12, 2009, 11:01 PM   #530
(formerly known as mini ifo)
aerolite's Avatar
Airbrush template technique
Here is a way to avoid having to tape your airplane. I used simple poster board from Hobby Lobby, cut my templates, and used large washers to weight them down. Works great, especially if you are using straight line templates.
One trick I've learned is to start with the lightest color, and spray everything needing the light paint. Next, move to the darker colors. As in my example, all the yellow was sprayed first, then red, and finally the black highlight was added last, including some large stripes on the bottom of the plane to aid with visibility and plane orientation. This will allow you to minimize your color changes, and save time.
This is really easy to do, and can be practiced on scraps before applying to your nice new model.
I hope the photos speak for themselves.
  • Name: airbrushtech2edit.jpg
Description: Yellow paint has been added.  See next photo for template used. Yellow paint has been added. See next photo for template used. 74.7 KB · Views: 30
  • Name: airbrushtech1edit.jpg
Description: Repositioning template for red accent Repositioning template for red accent 63.3 KB · Views: 31
  • Name: airbrushtech3edit.jpg
Description: washers used for template weight.  White triangle piece in middle is in place to prevent overspray. washers used for template weight. White triangle piece in middle is in place to prevent overspray. 77.7 KB · Views: 34
  • Name: airbrushtech4edit.jpg
Description: red paint has been applied.  The white triangle in the middle is removed, and red highlight added. red paint has been applied. The white triangle in the middle is removed, and red highlight added. 79.7 KB · Views: 36
  • Name: airbrushtech5edit.jpg
Description: after template is removed.  Black accent can be added by repositioning template and spraying again. after template is removed. Black accent can be added by repositioning template and spraying again. 72.1 KB · Views: 36
  • Name: airbrushtech6edit.jpg
Description: More photos of template in position and weighted. More photos of template in position and weighted. 56.4 KB · Views: 26
  • Name: airbrushtech7edit.jpg
Description: After red background and black highlight. After red background and black highlight. 52.6 KB · Views: 31
  • Name: airbrushtech8edit.jpg
Description: Yellow and red before black accent. Yellow and red before black accent. 44.9 KB · Views: 32
  • Name: airbrushtech9edit.jpg
Description: Finished product with black accent Finished product with black accent 36.1 KB · Views: 32
  • Name: airbursh Osiris 002edit.jpg
Description: And here is my Fancy Foam Osiris, custom painted using this technique. And here is my Fancy Foam Osiris, custom painted using this technique. 70.1 KB · Views: 52
aerolite is offline Find More Posts by aerolite   Reply With Quote
Old Nov 13, 2009, 01:10 AM   #531
Nice tip and looks good too.
Mine is assembled and ready for crashing... err flying.
  • Name: Guppy QB (Quick Build) 02.jpg
Description: Guppy QB (Quick Build) Guppy QB (Quick Build) 98.9 KB · Views: 28
  • Name: Guppy QB (Quick Build) 03.jpg
Description: Guppy QB (Quick Build) Guppy QB (Quick Build) 95.5 KB · Views: 22
  • Name: Guppy QB (Quick Build) 04.jpg
Description: Guppy QB (Quick Build) Guppy QB (Quick Build) 99.4 KB · Views: 32
Old Nov 13, 2009, 04:35 PM   #532
Out the Window
High Flyin''s Avatar
Yes, poster board or heavy paper makes a quick and effective mask. I use some old posters..free! It is also great if you are trying for a symetrical design. Just cut one side and them give the poster board a quick wipe to get off the wet paint and flip it over to do the other side.
Ray
High Flyin' is offline Find More Posts by High Flyin'   Reply With Quote
Old Nov 14, 2009, 01:34 PM   #533
philba's Avatar
Anything flat and rigid makes a good mask. Heavy paper can absorb the water from acrylic paint and curl up - not good for intricate patterns. I use plastic dividers from school notebooks. During back to school sales, they are sometimes very cheap. Quite durable and they lay flat.
Old Nov 15, 2009, 08:01 AM   #534
Simply Dusty
Danfive0's Avatar
It works, makes the foam very rigid as well. As for the warping, its mostly from being wet with paint once dry to the touch lay the pieces flat w/ possibly weights on them. They'll be straight as a board and more rigid.
Danfive0 is offline Find More Posts by Danfive0   Reply With Quote
Old Nov 15, 2009, 11:03 AM   #535
rossmkly's Avatar
Send a message via Yahoo to rossmkly
I use mylar from a local drafting supply house. Once or twice a year they clean house of old drawings, all done on mylar 24 x 36 inch sheets. I print out the full size PDF of the plans on paper and sketch up the color scheme I want to use then lay the mylar over the plan, trace and make cut outs for each color. The mylars last for a very long time and can be cleaned up with solvents when they get gunked up.
rossmkly is offline Find More Posts by rossmkly   Reply With Quote
Old Nov 18, 2009, 03:11 AM   #536
Location: Raleigh/Durham Intl, North Carolina, United States
Thanks for your videos adreher! This is my first paintjob and I couldn't have done it without watching your videos and others on youtube
  • Name: Img_2227.jpg
  • Name: Img_2228.jpg
Steve H. is offline Find More Posts by Steve H.   Reply With Quote
Body Painting - Type of Paint - Tips - Flaking Off Jeff F rec.models.rc.land 5 Feb 26, 2008 09:36 AM
Tips for Taking Videos? kelvin Electric Plane Talk 48 Apr 18, 2003 02:55 PM
Scratch builder's miniture miter at harbour freight splatman Scale Electric Planes 0 Feb 09, 2003 12:46 AM
Gimme some paint scheme ideas for the Pico Jet Pierre Audette Foamies (Kits) 7 May 23, 2002 09:32 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 05:28 PM
