Thread Tools |
| This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies. |
#226 |
Kv
Is it possible to have a motor which weighs around 70 grams, has a low KV rating of 500? I cannot find anything out on the internet. Is it possible to build a motor like this? Weight can be 70 - 100 grams.
Power 150-220 watts. Most importantly it has to be 400 - 500kv. Am i dreaming? Simon
#227 | |
http://www.rcgroups.com/forums/showthread.php?t=777998 This motor could take a few more turns of 22AWG and give you 500kv. Timocharis wound 18T of 22AWG and has pics that shows plenty of room for more winds. |
| criminallawyer |
This post is temporarily hidden while criminallawyer edits it.
#229 | |
I make the flux rin a little smaller and mill or broach flats into it to hold each magnet and give the right air gap. This gives an optimal magnetic circuit by eliminating the air gap where the magnet meets the flux ring and also holds the magnets in position during assembly. |
#230 | |
A Variac is an adjustable autotransformer with 110 volts AC in and output adjusted to be lower or higher than 110 AC. |
| divorce certif |
This post is temporarily hidden while divorce certif edits it.
#232 |
Nothing but the blood of Jesus
Tim is a very knowledgeable source for motor building performance.
#233 |
homo ludens modellisticus
Yep. That's why I reported him
![]() I will remove these three messages later. It's great to be a dictator ![]() Vriendelijke groeten Ron
#234 |
I have a Scorpion S-4025-16 brushless outrunner motor. When you try to run the motor the rotor tries to spin with the out side of the motor case pulling the wires inside the case. I took the rear end plate off of the motor and the rotor stayed inside the case. How do I keep the end plate shaft housing to stay inside the rotor. Do you use some sort of epoxy, glue I did see some silocone around the tapered part of the housing where it slides into the rotor. HELP !!!! HELP !!!! HELP !!!!!!
#235 | |
Magic Smoke Liberation League
I would recommend contacting Innov8tive Designs and seeing if they will repair it for you. From my limited experience, their stuff works well and they stand by it. Tim |
#236 | |
Thanks for the help Tim, I was hoping to do some sort of repair myself. |
#237 |
Guys, I try to keep this thread lean and mean, I will remove your posts, and this one, in due time.
| cd-rom motor conversion homepages/tricks/sources/discussions | Ron van Sommeren | Parkflyers | 5 | May 21, 2008 06:50 PM |
| 32X CD-Rom Drives--FOR SALE | kist2001 | Aircraft - Electric - Airplanes (FS/W) | 0 | Apr 23, 2002 05:33 PM |
| Looking for dead CD ROM (36x or faster) | Jim McPherson | Aircraft - Electric - Airplanes (FS/W) | 13 | Apr 12, 2002 11:47 PM |
| Paul Matt on CD-ROM? | tiggs | Scale Electric Planes | 2 | Mar 26, 2002 09:07 PM |
| F/S Realflight Sim.. CD-Rom | jfruge | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 29, 2001 09:17 AM |
