Go Back   RC Groups > Vendors > Hacker Brushless
Old Sep 30, 2009, 08:58 AM   #1
How fast can you crash it.
pletang's Avatar
What does it mean, 3 sec run, verry hot.
I decided to plug this motor in last night. After 3 sec run, it is verry hot, I was running it on 3S to test.
B50 9XL 6.7:1
pletang is online now Find More Posts by pletang   Reply With Quote
Old Sep 30, 2009, 10:21 AM   #2
Oly crap.. Deese ease not gud!
hpapilot's Avatar
Send a message via AIM to hpapilot
The motor got very hot after only 3 seconds of run time? What speed control and what prop?
hpapilot is online now Find More Posts by hpapilot   Reply With Quote
Old Sep 30, 2009, 11:06 AM   #3
pletang's Avatar
CC80 setup is default. It was working ok before. I have not check amps, will do tonight
Old Sep 30, 2009, 04:23 PM   #4
Never enough power.....
FL62's Avatar
Does the motor and gearbox spin freely? An idea of current draw would help. Most any motor will develop some amount of heat while free-running it, so it kind of depends on how "hot" it actually is. 125 F feels pretty hot to the touch when you are squeezing the motor in your hand while running it up....
FL62 is offline Find More Posts by FL62   Reply With Quote
Old Oct 01, 2009, 08:04 AM   #5
pletang's Avatar
Put the Watt meter on last night. The motor does spin, amps, one click on the power stick and the amps started at 5 and then it bounces all over the place I have seen 12, 30, 14, 40, 8, 5 ,12 and them the motor stops running and I can not hold the motor. When I test my 11XL is hold 8amps and it is not hot at all.
Old Oct 02, 2009, 01:20 AM   #6
FL62's Avatar
sounds like the motor has a loose connection in one of the phases, ar possibly in a connector or something. Are you using bullet connectors or something similar?
Old Oct 02, 2009, 07:49 AM   #7
pletang's Avatar
I did run with bullet connectors, by process of elimination, I removed the connectors and I am running aligator clips for testing. I did noticed that were the three wires goes in the casing there is no rubber insulation were the three of them are close together.
Old Oct 02, 2009, 05:42 PM   #8
pletang's Avatar
When I spread the three wires apart, as far has passoble, the running hesitation dissapears and there is less heat.
Old Oct 02, 2009, 09:08 PM   #9
FL62's Avatar
It sounds as though the wire insulation was worn away - the easy fix is to simply re-insulate the wires using shrink-tubing. Try to get one large pieceslid as far down each wire into the motor as possible.
Old Oct 03, 2009, 06:40 PM   #10
pletang's Avatar
You know what, I will be sending it in for maintenance instead.
LiPos, No lower than 3 volts. What does that mean? HankF Batteries and Chargers 1 Mar 25, 2004 08:40 PM
Motor Volt Rating; What does it Mean? kelvin Beginner Training Area (Aircraft-Electric) 3 Feb 11, 2002 01:02 PM
Question "balloon" what does this mean? omega blood Parkflyers 14 Jan 26, 2002 12:28 PM
Wing Loading,and Wing Area what does it mean? slabs Power Systems 3 Nov 26, 2001 09:47 AM
Flashes inside S280 what does it mean? JoeR Power Systems 3 May 25, 2001 12:04 AM
