Jul 05, 2019, 03:05 AM
Good vibrations.
dynexhobby's Avatar
New Product
New ESC's for high powered EDF
Hi guys
After spending the last 6 years perfecting EDF performance, DynexHobby have been busy partnering with APD to release a new line of super light, high powered electronic speed controllers for EDF. These ESC's come in two varieties 120A and 200A. So what is so special about these ESC?
- Deliver high power to your EDF without sag.
- They are the smallest & lightest ESC for power output on the market.
- Low cost.
- These ESC's have an advanced machine learning feature. It learns your motor configuration just by connecting to a battery and running the EDF. You don't need to program your motor details at all!
- They automatically accept any LiPo’s up to 12S (120A ESC) or 14S (200A ESC). No programming required.
- 32Khz switching.
- Powerful 32bit F3 processing power.
- Motor reverse using ESC onboard solder tab. No longer will you have to physically swap the motor wires to change direction!
Please visit our webstore for more details at http://dynexhobby.ashop.me/c/4616694...mium-escs.html
Note: Our ESC's have been programmed to work with EDF's out of the box.
and of course, if you need to balance your fans check out our Impulse 2 dynamic balancer
Regards
DH
Jul 05, 2019, 03:18 AM
Good vibrations.
dynexhobby's Avatar
Videos
Here are some videos of EDF's under test using;
The 120A on stock Dr. MadThrust 90mm EDF
APD 120Amp ESC Test for 90mm EDF (0 min 20 sec)
and 200A on 110mm EDF (battery not at full charge).
APD ESC on DynexHobby's JETFAN 110 PRO & 700-98-780KV setup. (0 min 44 sec)
HSD F-16 Taxi test...wings off
HSD F-16 on Jetfan 110mm with APD 200Amp ESC (1 min 39 sec)
enjoy
DH
Jul 05, 2019, 03:56 AM
jofro
Sounds like a dream come true if it's true, where is the flying action video? Models don't fly with out the wings. I want to see it in action!
Jul 05, 2019, 04:17 AM
Good vibrations.
dynexhobby's Avatar
Ha ha... watch this space
Jul 05, 2019, 05:56 AM
I want 1 of each! I've paid $380USD for CC 160A ESC's in the past, so I think that these are reasonably priced. I know the multirotor guys use APD ESC's and they're a great performer.
Jul 05, 2019, 08:19 AM
Lynxman's Avatar
Very interesting. What do they weigh?
Jul 05, 2019, 08:55 AM
atreis's Avatar
No heatsink needed?
Jul 05, 2019, 10:09 AM
Do you have a 16-18S special order option? What are the dimensions? What is the weight? Did I read that it has free wheeling? Can I reverse the rotation from a free channel in my radio? I see the price is right. Please answer these questions for both ESCs.
Scott
Jul 05, 2019, 11:50 AM
AKA Terry Till
ex-racr's Avatar
here is a high performance thread:
https://www.rcgroups.com/forums/show...1-APD-F3x-ESCs
Will your ESC’s come ready to run with caps, throttle lead, motor and battery leads and flashed with the correct software?
Current quad copter ones aren’t.
Here is the other thread on them:
https://www.rcgroups.com/forums/show...0S-ESC-choices
Jul 05, 2019, 05:01 PM
Good vibrations.
dynexhobby's Avatar
120A = 20grams (0.7 oz)
200A = 36grams (1.27 oz)
Jul 05, 2019, 05:04 PM
Good vibrations.
dynexhobby's Avatar
Originally Posted by atreis
No heatsink needed?
Nope! All that is needed is to place the ESC in the ducted airflow. This is a new breed of ESC, it uses high-speed processing and propriety software to pump power efficiently to the EDF. However its not recommended to place heatshrink wrap over the ESC, but you can coat it with a polyurethane conformal coating.
Jul 05, 2019, 05:13 PM
Good vibrations.
dynexhobby's Avatar
Scott
Hi Scott
Maximum of 12S for 120A and 14S for 200A.
Dimensions for 120A (70mm ◊ 30mm ◊ 20 mm) and Dimensions for 200A (73mm ◊ 34mm ◊ 20 mm)
Weight 120A = 20grams (0.7 oz) and 200A = 36grams (1.27 oz), without leads.
Reverse rotation only when setting up ESC, so can't trigger by free channel. However you have me thinking ...
Yeah price is great for that kind of performance.
regards
DH
Jul 05, 2019, 05:18 PM
Good vibrations.
dynexhobby's Avatar
Will your ESCís come ready to run with caps, throttle lead, motor and battery leads and flashed with the correct software?
Current quad copter ones arenít.
Hi ex-racer
The ESC's come with caps. We don't supply throttle, motor and battery leads as there are endless motor/battery configurations to cater for EDF Jets, so it's far easier for the modeller to use their own .
These ESC's have been flashed to work with standard radios out of the box. They can also be upgraded when new firmware is released.
DH
New Product FrSky New Arrival - FrESC32_80A Dual SBEC & High Power ESC AndreaHuang FrSky 207 May 15, 2019 08:35 AM
New Product new esc great for up to 6s edf's... check it out horsefeet Electric Ducted Fan Jet Talk 0 Dec 08, 2018 12:09 PM
Discussion New high power 80mm EDF Tim Wan Electric Ducted Fan Jet Talk 5 Sep 26, 2014 12:09 PM
Discussion new high power EDF cabou High Performance 6 Feb 09, 2006 11:58 AM
li-poly cells for high power EDF's? Doc Watson Electric Ducted Fan Jet Talk 18 Sep 26, 2003 02:32 PM
