Jan 12, 2015, 10:57 PM
New Product
West Michigan Park Flyers Vengeance
West Michigan Park Flyers LLC is proud to bring you the Vengeance.
West Michigan Park Flyers Vengeance (1 min 28 sec)
Jan 12, 2015, 10:58 PM
Pictures
Build log
We are roughing out the build instructions. Here is the rough text so far. We will be adding more text and cleaning it up and eventually making it into a PDF for download.
Vengeance Build Instructions
Begin by Identifying parts included in your kit.
1.3lb EPP 6mm Plane parts
2mm Depron Plane Parts (Note these are not going to be used and are being discontinued)
Wooden Control horn set
CARBON Fiber
3mm X .5 Strip
2 pcs 5-1/2 in. long (counterbalance brace - wing)
1pc 26-1/8 in. long (wing spar)
1 pc 1-1/2 in. long (tail skid)
1 pc 7 in. long (Fuse Angle Bottom Fuse)
1 pc 7-1/4 in. long (Fuse Angle Top Fuse)
1 pc 7-5/8 in. long (Rudder Angle)
2 pcs 14-1/4 in. long (Trailing Edge Ailerons)
1 pc 27 in. long (Leading Edge of Wing)
2 pcs 16 in. long (Horizontal Fuse sides)
3mm x .8 strip
1 pc 13-5/8 in. long (elevator spar)
2 pcs 8-3/4 in long (Motor mount diagonal braces)
2 pcs 13-5/8 in. long (Aileron Hinge Torque Rod)
1.2mm solid cut the following for trussing
2 pcs 4-5/8 (#1)
2 pcs 5 (#2)
2 pcs 4 (#3)
2 pcs 4-3/8 (#4)
2 pcs 4-1/2 (#5)
2 pcs 5-1/2 (#6)
2 pcs 7-1/4 (#9)
2 pcs 6-3/8 (#10)
2 pcs 4-1/4 (Canopy Brace)
1 pc 18-1/5 (Rudder Control Rod)
1 pc 16 – 1/4 (Elevator Control Rod)
2 pcs 11-3/4 #8 wing strut
2 pcs 11-3/4 #7 wing strut
1.5mm solid
2 pcs6 in long (Aileron Control Rods)
Piano Wire
Standard Straights (4 Pcs)
Standard Z bends (4 pcs)
Heat Shrink
2in long (4pcs)
Building The Wing.
Begin building the horizontal fuse upside down. (Logo Up) Separate the leading edge portion of the wing and glue on the spar to the front half of the wing only. Use a straight edge to ensure that the spar is straight and flat. After the spar is dry re glue to the wing gluing the center section of the wing between the ailerons only.
Separate the back section of the wing behind the spar from both sides of the wing. Locate the section that will connect the wing to the horizontal Stab and elevator and glue it to the main wing center section. Glue the horizontal stabilizer and elevator. Using a straight edge along the center tab slots, pin the horizontal fuse to your build board so it is straight and square to the wing spar.
Locate the 2 pcs of flat carbon for the fuse sides and glue in place between the horizontal stab and wing spar.
Working on both aileron sections of the wing, glue in the flat carbon for the aileron counterbalances. Glue the section behind the hinge line on both sides and ahead of the hinge line on the counterbalance side only. IMPORTANT: Don’t glue both sides ahead of the hinge line or your aileron will not move!
Pin flat and let dry.
Glue both aileron sections to the main wing ensuring that no glue gets between the foam on the moving sections of the aileron inboard edge or counterbalance section of the wing.
Glue on the leading edge flat carbon using pins to hold it tight to the wing.
Glue on the nose section to the flat carbon fiber leading edge. There are small cuts in the foam to help center the nose section on the wing.
Glue on the flat carbon aileron torque rods to the section of the aileron right behind the hinge line.
Glue on the flat carbon elevator spar rod to the section of the elevator behind the hinge line.
Slide the fuse forward on the build table or board so the nose hangs over the edge and glue on the firewall ensuring that it is straight square and centered.
Glue on flat carbon 3 x.8 from the corner of the firewall extending back over the wing spar fuse side carbon fiber intersection to the hinge line of the aileron. (note: this flat carbon is going to be used in place of the depron pcs. We have found it to be just as stiff while keeping the build lighter.)
The horizontal section of the plane should now be complete.
Vertical fuse section.
Glue in the flat carbon to the rear section of the vertical fuse and rudder. Glue in the rudder control horn.
Glue on the bottom fuse ensuring that it is straight and square as well as tight against the wooden firewall.
Block the bottom fuse with a suitable straight edge. I like to use a piece of angle iron. Let dry for a few hours.
Cut and place on the bottom trussing without glue. adjust all the trussing sighting down the bottom from the nose to the tail to ensure it is straight and square. When you are satisfied that it is as straight as you can get it carefully glue the carbon in place from the front to the back on both sides. Double check that nothing moved and that things are still straight and square. Let glue dry before proceeding any further.
Flip the plane over and block it up on same height objects. I like to use full cans of soda or old vcr tapes.
Last edited by WMParkFlyer; Mar 18, 2018 at 04:53 PM. Reason: adding text to images
Jan 13, 2015, 07:34 AM
God is Good
TMAC4123's Avatar
Very happy with the way this plane turned out
Jan 18, 2015, 02:46 PM
OSMBuddha
nagayama13's Avatar
Building
Going good...not much different than a normal build.
Jan 18, 2015, 08:51 PM
Black Label Society
RG167's Avatar
Why has no one thought of this before?! Nice plane, I have to get one
Jan 19, 2015, 08:04 AM
God is Good
TMAC4123's Avatar
[QUOTE=nagayama13;30519243]Going good...not much different than a normal build.[/QUOTE
nice build
Jan 25, 2015, 09:01 PM
OSMBuddha
nagayama13's Avatar
Question
I'm guessing that the cg is on the spar just forward of the tail servos...?
Been rather windy here btw. Will maiden as soon as it dies down! Maybe I can get Nick to shoot some vid...maybe. lol
Jan 26, 2015, 07:54 AM
God is Good
TMAC4123's Avatar
Using a 325mah 70c 2 cell I had the battery about 1 inch back from the nose and adjusted from there.
Jan 30, 2015, 07:46 PM
StevenMcC's Avatar
Very nice!
Feb 01, 2015, 01:08 AM
This is BAT country!
Gonzo 1971's Avatar
So what is the deal with this one? It had depron parts in the build to stiffen it up? Now it does not? It does seem to have a bunch of carbon to stiffen it up in order to fly like depron? Not much info out there. What makes this one good? What does it excel at? No info out there yet!
Feb 01, 2015, 02:57 AM
Black Label Society
RG167's Avatar
I've talked to Barb from WMPF (nice lady), she said they're working out a few things and the final version should be great. That's all I know.
RG
Feb 01, 2015, 09:53 AM
Gonzo 1971's Avatar
I am sure it will be great! I see, it is not fully released. Looking forward to this one...
Feb 01, 2015, 10:13 AM
Black Label Society
RG167's Avatar
I love the paint on it too, I believe they'll be selling it with an option for the "lightning bolts" instead of their traditional flames.
Feb 01, 2015, 02:34 PM
This is as close as we have got as far as measuring the CG without putting it on a stand.
For Sale West Michigan Park Flyers Vengeance LPU/ Can deliver to Toledo Show TMAC4123 Aircraft - Electric - Airplanes (FS/W) 0 Mar 15, 2017 07:08 AM
