Sep 09, 2019, 08:46 PM
Build straight - Fly twisty
Whiskers's Avatar
Very nice indeed.
The last landing is one for the highlight reel
Sep 09, 2019, 08:58 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Nice bit of flying there Bob, lovey place to fly off water, pond/lake is just a nice size and the surroundings are really nice, maybe we can go there for a fly when I came over
Lockey
Sep 19, 2019, 11:26 PM
Lockey's Avatar
I got to thinking after seeing your Vixen fly Bob and thought it was looking a bit dated .. so I have decided to do a bit of a face lift and will now be able to take a 8" prop and lower kv motor for quieter running
Hope you like it ..
Lockey
Sep 21, 2019, 06:26 AM
Lockey's Avatar
I wanted a sea plane to fit in my suitcase, .. small .. light .. one that I know (or felt) would fly ... and able to be put together really quick at the other end .. not too worried about bringing it back ( I will leave it with my friend) so it can be glued together when I get there but almost ready built ..
Here is my mini suitcase Vixen 620 (620mm being the wing span) just minimum glue holding it together to test fly, I will break it apart into 3 sections
Took me less than a day to cut it out and put it together .. used mainly CA glue and hot glue to hold the 3 sections together so I can pull them apart reasonably easily
Floater-Jet Replacement Motor AXN 2208 2150k
5 x 5 Prop
Plush 18A ESC
3 x 9g servos
Weight (without battery) 270 grams
Weight with 1000/3s batter 370 grams
Lockey
Sep 21, 2019, 09:33 AM
Lockey's Avatar
Maiden video
Lockey
Mini Vixen 620 Maiden (6 min 34 sec)
Sep 21, 2019, 01:11 PM
skumgummi dave
Lockey:
Your video is marked private. We can't access it.
Dave-
Sep 21, 2019, 02:37 PM
Retired CAD guy
birdofplay's Avatar
I'm thinking that it might not be fully up-loaded yet
Else,
Youtube has some settings specific to your upload that need to be changed
Under "VISIBILITY" on the right side of the screen
Sep 21, 2019, 03:32 PM
Retired CAD guy
birdofplay's Avatar
Tony has sent tentative files for both a 750 and 850 span version of his Traveling Vixen.
I have them prepped and ready for a test cutting.
More as the plot thickens ;^}
Bob @ Hoosier Cutout service
Sep 21, 2019, 08:35 PM
Lockey's Avatar
Sorry about the "private" video guys .. not sure what happened, never done that to me before .. although You-Tube have been messing A LOT with their settings .. if its not broke why fix it
I am away for a couple of weeks so Bob is going to build my new 850 design of the revamped Vixen .. thats right isnt it Bob ? watch this space for LOTS of build pics and a maiden video from Bob
Lockey
Sep 21, 2019, 09:59 PM
Retired CAD guy
birdofplay's Avatar
I'm ready to cut those 1st prototype parts!
It's pretty boring in Adelaide , you might forget to come back home !
But don't miss the boat as it's a long hard drive across the Nullarbor Plain !
I spyed that "Longest Straight Road" from the air on the way back from Perth !
I thought that I80 across Utah was bad, but, WHEEW , thats a stretch of road !
Sep 22, 2019, 09:06 AM
Lockey's Avatar
It sure is a Looooooooonnnnng straight road Bob
I think the 850mm wing span should be a really smart flier with maybe a 1000 - 1350 kv motor and a 8/9" prop .. should fly really slow .. and fast too
Once cut out should only take one and half to two days to build, this type of model is a very quick build and I have simplified the position of the 3 servos for ailerons, elevator and rudder .. I expect it to come in at about 700-800 grams including battery
I am thinking
Turnigy Aerodrive SK3 - 3530-1340kv motor or similar
8 or 9 x 4.5 prop
Plush 40A ESC
3 x 9 gram servos
5 mm CF tubes in wing, horizontal stab and 3 or 4 mm CF in booms
Oh yes .. and I think new thread and new name .. this one named by Bob .. "Viking"
Lockey
EDIT .. Here you go Bob .. new thread started ... https://www.rcgroups.com/forums/show...0#post42790285
Sep 22, 2019, 09:20 AM
Retired CAD guy
birdofplay's Avatar
Good thoughts.
No problem with equipment either.
Viking was just a preliminary suggestion , but, ... Hey if you like it I'm good too ;>}
Sep 22, 2019, 09:26 AM
Lockey's Avatar
This is the second flight of the mini Vixen 620 ..
I just added a bit of trim tape to make it easier orientation, flies quite nice, just have to remember to keep the speed up a bit on the turns and landing
Yes Bob, I like the name "Viking" for the big one
Lockey
Mini Vixen flies again (7 min 13 sec)
Sep 22, 2019, 12:23 PM
Retired CAD guy
birdofplay's Avatar
I like that everyone there seems to view the Goal as a Target !
OH OK you moved out there to be part of the target.
Is there a Height limitation at this Field ?
Looks like everyone has terrific Ground range ;^}
Sep 22, 2019, 01:01 PM
Retired CAD guy
birdofplay's Avatar
Viking thread started here
https://www.rcgroups.com/forums/show...NG-850-mm-span
or here
https://www.rcgroups.com/forums/show...-and-sea-plane
Sep 23, 2019, 01:21 AM
Lockey's Avatar
Pulled to bits and ready to travel, spray the hot glue bits with Meths and leave for 30 seconds and peel off
Lockey
Build Log Dedicated GOPRO delta airplane take off from grass+water+snow+hand launch: POLARIS XL ggtronic FPV Talk 133 Apr 30, 2017 04:47 PM
Question Recommendations for flying off grass and snow, maybe even water. Iflyjets Foamies (Kits) 10 Feb 27, 2013 06:34 PM
Question Water Slide or Vinyl Decals Fast Freddy Scale Kit/Scratch Built 6 Jul 03, 2004 07:02 AM
Another water slide decal question Red Baron 47 Electric Plane Talk 0 Oct 31, 2001 10:50 PM
Decalcote for water slide decals, where to buy? Red Baron 47 Electric Plane Talk 9 Oct 31, 2001 09:49 AM
