Nov 08, 2015, 04:57 AM
Team Armattan
Rob2160's Avatar
Originally Posted by bengtb
Help required
I am trying to flash a "" HobbyKing XP 3A 1S 0.7g Brushless Speed Controller"" using a "Afro usb programmer" Separate power to the esc but still get the error message:
" Stk500v2 Connection to esc at com 9 failed!
(error:"CMD_SIGN_ON: read Timeout (no answer)" "
what am I doing wrong?
Your ESC has a Silabs chip so will likely need to use an Arduino in C2 mode for the initial flash.
If you download and read the manual that comes with BLHeli suite called 'BLHELI programming adapters' it explains more.
Here is a video of the process for initial flashing with an Arduino then later flashing via the bootloader.
Flashing BLHeli 14.2 to Q-Brain 4 in 1 ESC (15 min 35 sec)
Nov 12, 2015, 04:43 PM
Thanks Rob after watching the video and an evening of fiddling I eventually managed to flash it
Nov 12, 2015, 05:22 PM
eventually?
Nov 25, 2015, 12:55 PM
lucbis's Avatar
Does anyone know if a turnigy trust 55A sbec esc is flahable with blheli and how
Dec 11, 2015, 06:24 AM
I COLLECT flyaway&lost drones!
martin555's Avatar
please somebody post a picture with markings:
which connectors are which on TURNIGY PLUSH 25A
it is with SILABS chip.
this is good?
https://www.hobbyking.com/hobbyking/....asp?TID=42806
Dec 11, 2015, 06:32 AM
https://github.com/bitdump/BLHeli/bl...abs%20ESCs.pdf
Jun 25, 2017, 02:22 AM
Bit of help needed if you can.
i managed to get 6 Plush ESC's 40amp which have been flashed with BLheli stuff.
They all work fine, BUT my issue is the spool up time for the motor from 0%-100% takes 5 seconds.
I got a Silabs USB Toolstick with them as well.
What software etc do I need to sort this all out please. No idea myself.
Jun 25, 2017, 03:48 AM
Emress
Blhelisuite
Jun 25, 2017, 03:59 AM
I downloaded that. But I couldn't get the esc to connect to it. ?
Jun 25, 2017, 04:09 AM
Emress
Check your wiring and make sure you have the correct programmer selected in blhelisuite
Jun 25, 2017, 07:47 AM
Okay, got it working, Changed spool up time from 9 to 0 and seems okay now.
Is there anything else I should change within this program, or know about on this?
I guess it doesnt know my motor (hobbykink Radjet 800 with supplied motor)
Many thanks
Sep 04, 2017, 09:59 PM
Just flashed by flyfun opto 40A (AKA turnigy Plush opto 40A) and getting some strange behavior in all but one of my motors. using latest arducopter and oneshot (oneshot 125 doesn't seem to work) 7/8 of the motors don't respond to throttle and sound very off like all the timings are wrong. They only work properly when pwm frequency is set to low. The 8th esc works fine and brakes in damped light. What could be affecting the ability to receive high freq pwm signals?
Here's a vid of the problem motors
ESC not working with damped light on using oneshot (0 min 50 sec)
And details of the supported esc blheli page for my esc's
The ESC supports 2S to 6S operation. It supports damped light mode. Switching speed is quite fast. Fet resistances are around 1.3mohm for low side and high side (typ at 10V). Both low and high side fets are Nfets. This ESC uses the same code as the Plush 40A ESC.
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 03:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Drone Talk 2 May 03, 2012 02:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Drone Talk 2 Jan 30, 2012 12:11 AM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 12:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 12:56 PM
