This thread is privately moderated by Coyote64, who may elect to delete unwanted replies.
Feb 19, 2011, 12:10 PM
Praying for better weather
Coyote64's Avatar
Dragon OSD Diagrams
Heres a few examples of Dragon OSD wiring diagrams. The first two below are of how to wire up the OSD for 5v and 12v components. These show how to configure the sheilding and placement of filters for interference free flying, minimal wiring and easiest installation:
System A :
Wiring diagram for basic 12v system using GPS and Current Sensor For a Delta wing airframe
12v Camera
12v VTX
DOSD seperate from current sensor
LC Filter
System B
This is a Multiplex twinstar diagram.
12v Camera with step up regulator, 12v Vtx, IMU stabilization, 2x Aileron, elevator throttle and rudder control. TRLS UHF system
System C
This is a general system, using two servo output although a third can be plugged in. OSD Throttle control, 5v Camera and VTX
These next system diagrams are simplified to just show sheilded cable runs and LC filter placements depending on flight pack sizes and equipment voltages
System 1 : 12v Standard system
12v Camera
12v VTX
DOSD seperate from the current sensor.
It has a LC Filter incorperated.
All equipment is after the current sensor so a true mah reading is displayed
System 2 - 12v step up system
12v Camera
12v VTX
LC Filter
Powered off the balance plug
Step up transformer used for constant 12 volt supply under load
System 3 - 4S 14.8v Supplied 12v regulated system
12v Camera
12v VTX
LC Filter
LM7812 regulates the 4S supply to 12v
Jan 02, 2014, 06:32 PM
DOSD and sn555
Hi. I'm having troubles with connecting SN 555 to DOSD. I have the video but only when I start not from the first pin. Weird. If I follow the instructions no video. Any idea????
Discussion Eagle Tree OSD Pro, Futaba 9c, Dragon Link Gundy Eagle Tree Systems 5 Aug 02, 2013 01:25 PM
Discussion New Dragon OSD or RVOSD3? IamLegend FPV Talk 24 Nov 03, 2010 02:26 AM
Discussion Futaba 9c, Dragon Link, Eagle Tree OSD Pro. Gundy FPV Talk 2 Oct 12, 2010 09:21 AM
Discussion Dragon link RSSI + Eagletree OSD PRO ecampos FPV Talk 2 Sep 09, 2010 12:51 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
