RC Groups
RC Groups
    Scratchbuilt Indoor and Micro Models
        Candle wax "bobbins"
#1 epilot Jan 06, 2004 12:49 PM
1 Attachment(s)
Here is a picture of a candle I just turned in my lathe. It is for winding coils with a 5mm center hole. After the coil is wound, add a drop of CA to set the coil, then put in boiling water to melt the wax. You don't need a lathe, just get some candles that are thin enough to chuck in a drill.
Michael
#2 j8m8l Jan 06, 2004 01:13 PM
Awesome Michael
Think I may try that for some coils I need to wind soon.
Josh
#3 Jgardner Jan 06, 2004 01:18 PM
Bonding
Will the wax then bond the coil? That would be slick if it did not weigh too much.
#4 epilot Jan 06, 2004 01:27 PM
You bond the coil with CA or another glue of your choice. Epoxy works well. The wax is melted away.
Michael
#5 epilot Jan 06, 2004 02:31 PM
The result
1 Attachment(s)
Here is the result - perfect little coil. I just emerged it in boiling water and all the wax disappeared as if by magic ;)
500 turns 0.05mm wire, 5mm ID, 85ohms, 0.3grams :)
All credit goes to Jeppe who showed me how to do it.
IMHO it is THE easiest way to make a bobbin-less coil.
Michael
#6 j8m8l Jan 06, 2004 02:35 PM
Beautiful Michael.
What glue did you use for that one?
Josh
#7 Dave Wulff Jan 06, 2004 02:39 PM
Michael,
Very slick..another "whish I had thought of that":D
Dave
#8 epilot Jan 06, 2004 02:46 PM
Josh, I used a drop of CA.
Dave, I'm hoping this is the way to go with the really thin wire.
Christmas candles should be on sale now, no? :D
Michael
#9 j8m8l Jan 06, 2004 03:04 PM
I think that I am gonna have to save up for a mini lathe/mill combo.
There is so much I could do !
Josh
#10 billystiltner Jan 06, 2004 04:03 PM
Michael
Nice.
When I unwind the superthin wire I do it by hand and the bobbin I wind onto has a loose fit on a dowel. I twist the dowel so if the wire gets caught up or tangled the bobbin slips on the dowel.
You might be able to make something like that with a drill , the wire is really easy to break. The wax is a great idea to wind the
coils on. No fuss with keeping the flanges tight or pulling the straw from the bit. Allthough the most recent one I wound was pretty easy. The wax seems easier.
Billy
#11 Trizza Jan 06, 2004 08:40 PM
Beautiful! Now that I have a lathe I'll have to try this - winding coils used to drive me insane because even if I managed a full coil I'd destroy it trying to remove it from the form. Maybe I'll build a winder too now that I have piles of sewing machine motors to use. Cheers!
#12 Trizza Jan 06, 2004 08:44 PM
PS - how was the wax to turn? Looks like it made a good finish.
#13 rustycage Jan 06, 2004 09:08 PM
How about those cheap thin birthday candles with paper/cardboard ends to make a bobbin or would that be too small for a coil? You could still melt the wax away and the paper would just fall off.
#14 dburley Jan 06, 2004 11:28 PM
Hmmm -- Lost wax coils !!
#15 Graham Stabler Jan 07, 2004 05:38 AM
Come on epilot you can do better than this, you should have cast the wax mould with the magnet embedded, that way you can have coils with a spherical interior!
