Note the NYLON clevis on bottom connection. I replaced the metal flying wire clevises with nylon to minimize the change of the flying wires acting as antennae!
Posted by: tailskid2 on Jul 19, 2006 05:47 AM
Much more fuel proof.
Metal clevis & rod used when connected to the rudder. The tailwheel arrangement placed NO stress on the rudder.
Elevator on the far side; the rudder servo in the middle; y-pushrod to each elevator half. Two elevator servos could've easily been done with one servo on each side of the rudder. The rudder servo must be centered for the pull-pull arrangement.
There was a lot of room in the front of the fuselage! If two elevator pushrods were used, the engine servo could be easily reassigned almost anywhere in the enormous fuselage cavity.
