Not too shabby looking is it?
Posted by: tailskid2 on Jul 19, 2006 05:47 AM
A template was made to fit inside the cowl.
Final backing was made of thin foam-board.
By removing one cylinder, engine cooling was accomplished. Engine cooling opening was smaller than the exit hole.
Easy access to set screw on needle valve. To access the needle valve a removable extension had to be utilized. By removing a section between the cylinders, access to the high speed needle valve was accomplished.
