The complete wing assembly. All that was required to complete each wing panel was hinging the ailerons with the included CA hinges and mounting a servo in each wing panel.
The wings slide on to two aluminum spars that pass through the fuselage. Two nylon bolts secure each wing panel to the fuselage.
The Fuselage has plenty of room for mounting all of the equipment.
The throttle servo sits by itself in the fuselage. It looks lonely since the elevator and rudder servos are mounted near the tail of the plane.
