Like its bigger brother the Destiny, the Mini Destiny needs a shim installed under the leading edge of the V-tail to fly without any elevator trim.
Posted by: gavoss on Jul 19, 2006 05:47 AM
I chose to use a carbon tube for the main portion of the elevator pushrod system. Then, I used two 2-56 rods with a balsa spacer and glued that subassembly into the tube. The system is very solid with no play at all in the elevator system. A JR 368 se
Here you can see the after market ball link setup and the relief cut into the fuselage.
Here is the radio installation in the fuse, and the canopy hold-down wire installation.
It's time to FLY!
