The rudder servo was mounted in the fuse and the pull-pull wires were routed out through the factory cutouts in the fuse.
Pull-Pull exits.
Motor mounted with 8-32 bolts from inside the firewall.
Spacing out the motor...the manual called for 3/4" in front of hte cowl to increase prop efficiency. (This is done on the full-scale yak as well!)
