I installed the provided Dubro control horns in the elevator halves and the Rudder pull-pull system. There was a small pilot hole in the hardpoints from the factory so all I had to do was drill it out the proper size and bolt the horns on.
Elevator control rod...Instead of the 4-40 all thread control rods I used 4-40 rods with a solder clevis on the end. This was just a personal preference as I like soldering control rods together. I used Dubro heavy duty control arms on the servos.
The rudder servo was mounted in the fuse and the pull-pull wires were routed out through the factory cutouts in the fuse.
Pull-Pull exits.
