Tail installed. I sealed the gaps on every surface using clear Ultracote.
Tailwheel closeup....The tailwheel was installed in the rudder before the hinges were glued by drilling a small hole in the front of the rudder for the tailwheel to stick into, then screwed to the bottom of the fuse.
Elevator control rod...Instead of the 4-40 all thread control rods I used 4-40 rods with a solder clevis on the end. This was just a personal preference as I like soldering control rods together. I used Dubro heavy duty control arms on the servos.
No problem getting lots of throw!
