Wing cutout...On each cutout, I left a 1/4" of covering and then folded it insidea nd ironed it down to ensure a tight seal.
Tail cutout -- I also ironed down a small edge here to keep the covering from peeling back.
Tail installed. I sealed the gaps on every surface using clear Ultracote.
Tailwheel closeup....The tailwheel was installed in the rudder before the hinges were glued by drilling a small hole in the front of the rudder for the tailwheel to stick into, then screwed to the bottom of the fuse.
