Go Back   RC Groups > Article Archive > Ezonemag Archive > Extreme Flight Yak 54 68inch ARF Electrified Conversion Review! > Extreme Flight Yak 54 68inch ARF Electrified Conversion Review!
Wing cutout...On each cutout, I left a 1/4" of covering and then folded it insidea nd ironed it down to ensure a tight seal.
Posted by: Steve H. on Jul 19, 2006 06:47 AM
There were 2 carbon locating dowels for each panel; here I have already roughed them up with 80 grit sandpaper prior to test fitting. I tested each dowel to ensure it reached to the next rib prior to gluing in place.
The locating dowels/antirotation pins installed in the wing.
Tail cutout -- I also ironed down a small edge here to keep the covering from peeling back.
After marking the stab's position on the fuselage, I "cut" the covering with soldering iron. This way there's no chance of an Xacto cutting into the wood and weakening the stab. (The stab's fit into the fuse was very tight -- great!)
