Hinges installed, using pins to ensure they remain centered while curing.
Servo installed with a 6" extension. I made sure to use locktite on the threaded rod & nuts after I got the servo setup properly. I used the 1" aluminum arms that came with the Hitec servos and had the recommended throw on the ailerons with them.
The locating dowels/antirotation pins installed in the wing.
Wing cutout...On each cutout, I left a 1/4" of covering and then folded it insidea nd ironed it down to ensure a tight seal.
