Servo openings cut open. There was not a pulling string in place, but none was needed due to large lightning holes.
Hinges installed, using pins to ensure they remain centered while curing.
There were 2 carbon locating dowels for each panel; here I have already roughed them up with 80 grit sandpaper prior to test fitting. I tested each dowel to ensure it reached to the next rib prior to gluing in place.
The locating dowels/antirotation pins installed in the wing.
